Question about Garden
Looking for a diagram of a peerless transmission part number 2o5-024B
  • 148 Answers
Try this link HERE.
Hope this helps.
Posted on Oct 04, 2009
Peerless tecumseh transmission model mst-206-545c will not drive in gear
FYI I have a Craftsman LT1000 18HP twin opposed Briggs with a Peerless transaxle 206-545c 6 speed manual trans (not the Hydrostatic). I was given this Lawn tractor by a friend who took real good care of it. runs starts great but it started binding in 3rd gear and was very hard to get it out.of gear so by pushing the cluch/brake in and out manytimes and forcing forward into 4,5,6 gears I was able to get it out of 3rd.
Iam a mechanic and have over 30 years experience.so I decided to research the Peerless 206-545c transmission I found some great info online and helpful repair vids on youtube. I decided to post here to try and help people that are having the same issue with this trans. after I got the tractor in the garage I noticed the left rear wheel was wet on the inside with gear oil.so I decided to do a rebuild.after learning about this transmission.I went to sears parts direct.com and put in my craftsman mower model number and it came up with a exploded view of the tecumseh\peerless 206-545c. on the diagram. I found the 2 transaxle seals needed item# 157 and for like 15 bucks ordered them. you can order all the seals if you choose.
I realized that there is a fill PLUG ONLY and no drain plug on the bottom of transmission.you must take this transmission out of the tractor and lay it upside down in a oil catch pan and drain the fluid out. you must open the transmission all the way to replace the transaxle seals.Im told that most lawn tractors of today have disposable transmissions.another words they dont want you to fix them youreself they want you to bring it in so they can charge you to diagnose it and say yep you need a new transmission. lol thats why no drain plug.so if youre not a mechanic you gonna be payin boy..
I did find alot of BAD info in doing research on this transmission online ie: people posted wrong info saying that you just have to loosen all bolts on the trans case and you can put new seals in... VERY WRONG and the other wrong info was the amount of gear oil. the correct amount of 80w90w is 32oz 2/3 full from top(use a dowl or straw to measure. I use LUCAS high Performance. gear oil. I included a Tecumseh/Peerless link for you to check out. http://www.smallenginesuppliers.com/html/engine- specs/tecumseh/Tecumseh_Transaxle_Service_Information.pdf scroll down to MST 200 series trans find the 206 545c documentation and it tells you every thing you need to know about the 206-545c ie 90/100 inch pounds when torqing bolts on case. shifting adjustment (ball hex screw adjustment) 1 full turn after flush with housing.etc. I was able to save this transmission I opened it up and cleaned every gear by hand with Seafoam trans cleaner and put it all back together using permatex (GEAR OIL GASKET MAKER) and waa laa it shifts amazing and no more leaking from axle seal. I get no benefit from posting this just want other people to have the correct info and for around 40 bucks you can recondition this trans.if you open it up and find broken gear or gears go to ebay or sears and get parts which ever fits your buget.it took about 6 hours total to de install transmission and clean gears and put new seals and re install back into the tractor. just to give you a time frame. if you dont have time to rebuild it go to ebay there are used complete transmissions there but I would rather know what I have by doing it myself than buying used that may have the same issue and cost ya 200 bucks.
god speed bruthas
Aug 12, 2013 | Garden
I am looking for a parts diagram of a Crypto Peerless F2F potato chipper
Parts diagram (exploded view) of a particular model (F2F) of a potato chipper manufactured by Crypto Peerless in the UK..........
http://www.ascateringsupplies.co.uk/ASCateringFileUpload/pdf/F2F!.pdf
Jun 07, 2012 | Heavy Machinery
I need a diagram for a peerless transaxle 855 Series
The Peerless brand is going through some changes. Here is the current info on the company.
http://www.peerlessgear.com/files/Peerless/splashimage_full3.jpg
Feb 15, 2011 | Garden
Looking for workshop manaul for tecumseh 205-204c so i can pull down to fix
Then number you have posted 205-203c is a Hydro Transmission. I know of no one that has that manual expect a Authorized Peerless Dealer.
Sorry
Oct 17, 2009 | Garden
Peerless Transaxle #206-545c locked up in 3rd gear, wheels won't
Sounds like your going to have to open up the tranny....
Sep 05, 2009 | Craftsman Garden
John deere transmission what other mowers interchange
You will have to first know what kind of transmission you have. You will have to consider if it is manual or hydrostatic drive. The transmission model number should be stamped usually on the top of the transmission. Yes transmissions are interchangeable, for example some John Deere, Craftsmans and Husqvarna all use the same transmission. Peerless is a manufacturer of these, the only one I know of. So don't let anyone tell you that you can ONLY use a John Deere product. To determine what transmission you can cross over with, get the model and serial number off of your John Deere's transmission. Call a small engine repair shop and ask them what all transmissions it will cross over with. Let them know you are aware that Peerless manufactures the same transmissions for most all riding mowers and that they will interchange. If they are uncoperative, contact me with the model and serial numbers off of your transmission and I will cross reference it for you. But try to get model and serial numbers for other brands from them, then check these against used ones. You will need to tell them if it is a hydrostatic transmission or manual and if so what speed manual.
Jul 11, 2009 | Athearn N Rtr John Deere Tractor Model B ...
Transmission is locked up.
Make sure all attachments are off the outside of the unit. If all bolts are out then if you have not try a chisel all the way around the case very carefully as it is usually stuck by the sealant that seals the unit.lol.donnyb60
Mar 23, 2009 | Mtd Garden
Garden Logo
715 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
