Cannot get my bluetooth to work
my blue tooth does not work
  • 74 Answers
Install drivers for your bluetooth and check hardware.
Posted on Oct 05, 2009
Bluetooth has power and buttons click when pushed, but does not respond.
I just got my blue tooth ear phone to work with my laptop, sounds like you want blue tooth car to pickup on your phone speech and sound. You probably have to enable blue tooth on your phone and connect to the bluetooth receiver in the car. Probably be good if blue tooth receiver is on so phone sees the signal, that's the way mine worked, it showed that device, I clicked it to connect. Hope that helps.
Jul 08, 2016 | 2008 Hyundai Veracruz
My p.c does not get any drivers for my sansui bluetooth headphones.
If you have other blue tooth devices working correctly, do a search for new devices on your blue tooth software. Pair the headphones using the blue tooth software.
Jul 15, 2015 | Audio Players & Recorders
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Bluetooth not working in sony W580i phone
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
Problems with Bluetooth
Just download the drivers of blue tooth on your notebook correctly man.
then spam me if it wont work cuz i tell you what the next solutions ok.
Oct 20, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
How do i turn the bluetooth on in my computer acer aspire 5520
Does it have blue tooth? Click "Start", "Connect to", "Blue Tooth", If that does not work, go to "Control Panel", then it should be there somewhere...
Jan 18, 2009 | Acer Aspire 5520-5908 Notebook
DRIVERS for blue tooth mouse kensington model 72414 serial # A0541002355
be sure that you have windows xp sp2 for bluetooth to be working properly. and 1 more thing, have you tried uninstalling and re-installing it?
blue tooth sometimes have problems regarding with the drivers because windows xp have a built in bluetooth drivers, if your bluetooth mous3ee have its own drivers, i reckon the fault may lie there..
Jan 04, 2009 | Computers & Internet
Blue tooth
Most phones that support bluetooth have a "headset" or "hands-free" profile that the device must be in for the bluetooth headset to work. Can you confirm that your device is in this profile?
Jun 06, 2007 | Motorola Mobility PC850 Wireless Bluetooth...
Computers & Internet Logo
David Payne
David Payne
