Question about Garden
It is a eb430 model...been taking care of it and never any problems for years. Today as i was pusing for gas it dies, as it was missing gas. I read a similar issue from another person where the suggestion is to change the fuel filkter. I will do that . Anything else i may try if that does not work Tx
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Replaced carb on Redmax Model
Hi and welcome to FixYa, I am Kelly,
What your describing is the lack of fuel. Check your tank pick up tube for blockage. Tank pick up tube filters are known to cause problems. Also make sure none of your fuel lines are cracked / split at the connecting fittings. If the feul lines are questionable... just replace them. You can get the hose in bulk at any lawnmower supply source then cut to length. If your sure you have good fuel flow then dial in the carb settings. Your replacement carb should be the HDA-80B.
The manual for the HDA-80B is here:
http://wem.walbro.com/distributors/servicemanuals/HDAseries.pdf
However depending upon parts source it may list the WT-252-1 as the replacement carb.
http://wem.walbro.com/distributors/servicemanuals/WTseries.pdf
What you should do is attempt adjustment.
First start with the L screw... and make screw driver blade width adjustments until the unit no longer hesitates when the throttle is advance.
Then adjust the H screw at MAX throttle until your can get max engine speed.
After that re-check the L setting by advanging the throttle rapidly. If you experience hesitation re-adjust the L screw.
Thanks for choosing FixYa,
Kelly
Posted on May 16, 2011
93 plymouth voyager 3.3 has spark and gas but won't start
Had the same problem with my 91 Voyager, just died, it would only start with the peddle floored and then sputter like it was missing or not getting fuel before dying. Went thru everything, ended up being a plugged cat. Popped it loose enough to allow blow by and it started right up.
Jul 24, 2016 | 1993 Plymouth Voyager
Brinks model 7236 will not light
Reviews on this product are low and say same thing you are experiencing.
That the light stops working, and will not work again.
Take the unit back to retailer and get money back.
Most electrical devices come with 1 year limited warranty.
Many of these outdoor lights today are now being made of plastic.
I have no idea why manufacturer's make a product that will not stand up to a windstorm.
I suggest a metal die-cast outdoor light fixture:
http://www.amazon.com/dp/B0013B1XQK/?tag=waterheaterti-20
Read product description, and look for die-cast, metal housing etc, and look carefully if the light is made of plastic.
Apr 17, 2013 | Hardware & Accessories
Had to change the batteries in the Atomix clock and now the
Hello
What is the Brand name and Model number of your Atomic clock?
Jan 04, 2012 | Audio Players & Recorders
I have a panasonic plasma hdtv. When I turn it on--usually--the red light flashes. It flashes continually--not in a sequence. I can keep pusing the power button and sometimes the tv will power on--but...
Must have to take the tv aparts,check the tv power supply board carefully.That the board where the tv a/c power cord plug into it.Look for dying and leakages capacitors components parts.These dying and leakages capacitors parts are causes this problems 90-95% of the times.These dying and leakages capacitors components parts are alway bulges up and or puffing up onto it tops.It dosen't supose to have a flat tops as those are good capacitors components parts that are alway have flats and even cyclinder head tops.If u have all the tools and know basic electronic and also u can do basic soldering work too than u must have to changes all these dying and leakages capacitors components parts that are bulges ups or puffing ups on to it cyclinders tops,will solved this tv problems LED power liight inconsistance staying on power LED light indicaton flashes.If u can't do soldering works on an a electronic board components levels works.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Dec 02, 2011 | Panasonic Televison & Video
Printer makes rapid, sharp snaping sounds just before and sometimes after printing.
It's a sign of a dying printer. My guess is that it is a plastic gear skipping or missing teeth. I've had several inkjet printers with this issue, but how long it will continue to work after hearing this can't be gauged.I had one printer that lasted almost 2 years after it began to "snap"... Another printer died in just a few weeks. What will end up happening is the printer will most likely throw an error up, and that's when it's toast. If it were a more expensive printer, it might be worth fixing, but this model can be purchased for less than $80.
There's a reason those printers are only $60 - $80. For your next printer, I suggest reading a LOT of online user reviews, especially if you are going to go cheap. There's nothing wrong with going cheap, but you have to be even more careful. When I buy printers, I even read the reviews for the ink cartridges it takes, just to see how long they really last.
Apr 03, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I have a 1999 Ford Explorer that wont run. It cranks and if I give it gas it will start but it doesnt idle at the 500 it should idle at it just dies. Ive read about the IAC and taken a look at it, its...
clean the iac, and then replace it. if its bad. check vacuum lines and run some good injector fluid in tank, maybe the injectors are clogging up. but clean iac first to see if this takes care of problem.
Nov 18, 2010 | 1998 Ford Explorer
Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Jun 15, 2009 | Boating
I have a 1995 Chevrolet S10 that seems to be missing on take off but once you get going it quits and runs fine until you come to a stop again and then on take off it starts missing again and then levels...
Change the fuel pump. Check first fuel presure.
fuel regulator. PVC valve stuck????
Check the vacum hoses and EGR.
Clean MAF mass air flow sensor.
check the IAC idle air control resistor.
Vitally
Jun 02, 2009 | 1995 Chevrolet S-10 CA Edition
Lg phone stopped reading SD card
Hi Archie Bald,
I know it's been 2 years, so I'm posting this for anyone with an LG.
Unfortunately, this is an ongoing problem with several of their models. To boot, cell phones in general seem to be produced today with a minimum of QC; models change so quickly, they really don't care about refining any one model. To make matters worse, I've owned several other LG products, 2 of which died on days 32 and 33 - after the return policy. Today none of my LG products work - indeed the longest lasting product got just over a year. While my experience may be bad luck, it's hard to call it that when it spans several of their products; indeed, some family members have had similar results. My current EnvTouch is my 5th swap-out. The longest lasting one was 34 days. Most people would say that at least the refurbs should be better... Not so for me, as 3 of them were refurbs. Touchscreen problems, sd card reader did what yours did, and the battery won't hold a charge overnight, and some genius engineer thought a quick-lock key combo wouldn't be necessary - so now it calls people in my case all by itself. IDIOTS. The p.o.s. is 6 months old.
Bottom line: RUN, don't walk - away from LG, forever and always... and remember that FTC Consumer Sentinel is your friend - file a complaint.
Jan 22, 2009 | LG VX8300 Cellular Phone
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
