Question about Norcent Technologies LT-2720 27 in. HD-Ready LCD Television
I have to keep turning the TV on and off about 10 - 15 times before the picture appears and my volume is always a loud hummin sound then goes away
  • 3,741 Answers
In your tv there is a main circuit board.its not the faulty main board.but on main board there are several components.called capacitors and IC.so in that some capacitors and IC have got loose and some are got faulty.so no need to replace the whole costly board.just some faulty components on the board needs to be replaced.you will have to check out the faulty components by multimeter.some of the capacitors will be bulged at its top and some will be leaked and some will look bit burned at the sides that are faulty and that needs to be replaced.you can get the required part at ------ www.radioshack.com -------- also the part number of the capacitor and IC will be written on its sides.the cost of per capacitor will be near to $2 and per ic will be near to $15 - $20.so the cost will we as per how much capacitors and IC have gone bad. ---------------- if you are not familiar with reparing/replacing the components yourself you can get it done by local tv repairing technician.and yes its worth repairing.this is common problem faced by many users and gets easily solved. ------------------- thanks.this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Oct 04, 2009
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
Tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Apr 01, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
YAMAHA YSP-1 SOUND PROJECTOR- LOUD STATIC NOISE FOR 30-60 SECONDS
had the same problem. Called Yamaha tech, They said try unplugging it it from the wall for at least an hour. That worked. Then it came back. My son the geek unplugged the cable where it goes into the unit and plugged it back in. Problem went away! So.... methinks it's as simple as keeping the contacts going into the wall outlet AND the plug going into the unit CLEAN. Here's a link on some good ideas on how to do that: http://www.naxja.org/forum/showthread.php?t=15476
Mar 25, 2009 | Yamaha Digital Sound Projector Home...
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
RCA 36 in. tv no volume
yes it is a electronic problem. as you get sound but it comes down again. it is mainly due to any loose contact in sound section or any capacitor is faulty.
Sep 30, 2007 | RCA F36650 36" TV
TV picture goes out and then comes back, TV eventually turns off
Probable bad DM module = repairable by qualified Mits.tech.....
Nov 13, 2006 | Mitsubishi WS-48613 48" Rear Projection...
Norcent Technologies LT-2720 27 in. HD-Ready LCD Television Logo
65 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
