Question about KitchenAid Ovens
The door handle is loose and I don't know how to get to the screws to tighten them.
  • stewart825 Oct 05, 2009
    Does the whole door have to be removed? If so, how?
    Sergeant:
  • 247 Answers
The heads of the screws are probably inside the door ,dissassembly of the door may be necessary to reach them
Posted on Oct 05, 2009
  • todd gentile
    todd gentile Oct 06, 2009
    i think from the bottom you can see the door arms and sprimgs
  • 8,197 Answers
To tighten the handle. You need to remove door from oven. Then you need to take door apart. Once the door is apart you will see the screws that hold the handle on. I recommend removing the screws then put lock tight on the screws then reinstall to handle. After you do that you need to put the door back together and reinstall on the oven. Be careful as you can damage the door it you do not put back together correctly.
Good Luck
Posted on Oct 04, 2009
    Sergeant:
    Champion:
  • 232 Answers
The screws are probably located on the inside of the door possibly behind another panel that will need to be removed first. all i can do without an model
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
How do I tighten the door handle on my maytag oven
Yes you need to take the inside of the door off. Usually a few screws. Then you will have access to the screws that hold the handle.
Jan 14, 2015 | Ovens
Loose oven door handle
you must remove the inner door panel to locate the screws so that you can tighten them. hope this helps!!
Apr 06, 2014 | Fisher and Paykel OB24SDPX1 Electric...
How to tighten loose handle
Remove the door gasket, that should give you access to removing door plate. Door handle may need to be replaced.
Oct 26, 2013 | Combi Steamer electric built in steam...
Open door handle is loose on a true temp GE stove how do I tighten the handle
You will need to unscrew and unfasten the inside door panel to access the screws that need to be tightened.
Jan 06, 2013 | Ovens
The door handle of my oven whirlpool gold model no GGP84803 is loose I try to get it off by prying it from the top with no luck seem to be jam or locked I am not sure how to proceed.
I had same problem, fixed by removing screws under door and removing side panels . Then remove front glass ( 4 screws under glass ) and remove other screws behind glass to remove handle and then tighten 4 screws on handle. Works great.
Dec 29, 2009 | GE Ovens
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Jan 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Dec 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
I would try putting some locktite on the threads so It wont come losse anymore.
Nov 07, 2007 | Ovens
Ovens Logo
150 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
