Question about HP Photosmart C5180 All-In-One InkJet Printer
How do i get the scanner to scan to my computer? It only gives me an option to scan to print or scan to memory card.
  • 159 Answers
SOURCE: HP OJP L7580 and VISTA no SCANNER available
You may want to try the full install before spending more time troubleshooting. It's a 300mb download (!), but it might be worth a try.
You don't say what software you're trying to use to scan, either; you may wish to try another one. If you want to experiment, you can download a free photo editing package that won't take over all your preferences for files -- check out portableapps.com and look for GIMP.
I've got an older HP printer, a PSC 1610, and it took me something like *seven* times installing it on Vista before it worked right. It turns out there's the regular uninstall, and then there's a super uninstall, and then there's a super duper uninstall, etc -- something like seven different uninstallation procedures, which is just insane.
HP's drivers and cruddy software convinced me to never by another one. It's a shame -- the company made some laser printers 15 years ago that are still working perfectly.
Posted on Jan 19, 2009
blueextc3221
  • 15935 Answers
SOURCE: HP C6280 won't let me scan to the computer. Only
ergo your problem!!
You must have scanning software installed on your PC in order for the 2 devices to communicate. It should have come bundled on the CD you got with the printer. I believe the HP software is called HPDirector.
Please find on your PC or install from your CD & that will enable you to scan to your PC.
It may already be installed. You will need to run the software to enable communications between the 2 devices.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
sys_admin
  • 829 Answers
SOURCE: HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
Posted on May 24, 2009
BcastTeacher
  • 14 Answers
SOURCE: How to scan to Apple computer
It sounds like your HP isn't seeing your computer since the only options it's offering do not relate to a computer. Have you checked to be sure your computer is seeing your printer? Can you print from your Apple to this printer?
Also, Apple has a utility called Image Scan that might work for you. Double click on the hard drive, then go to Applications>Image Capture and see if that program will see your HP. If it will allow you to select the HP. If it doesn't see it, you might be able to go to Devices in the menu at the top and have it search for the HP. You might need to use the TWAIN UI to help you connect.
I have found Apple computers to be more difficult to attach (and keep attached) to scanners than PCs (even thought i hate to admit that!)
Posted on Aug 29, 2009
  • 5097 Answers
SOURCE: Wont give me the option to scan to the computer.
Do you have the full-featured software and drivers loaded on the computer? Is the computer able to see the all-in-one as ready? Try a new USB cable and plugging the all-in-one into a different port. If you are using a hub, try directly connecting to the computer. Can you scan if you start the scan software from the computer? (this is a common issue if you recently moved to a new version of your operating system and the all-in-one hardware buttons are not fully compatable with the new OS.)
I hope this helps.
Posted on Mar 19, 2010
I am trying to scan documents and images into my computer and also email but apparently i can only choose from "scan and reprint" or "scan to memory card" options? Please help!!
If your HP Printer is connected to the computer it should be able to save the scanned images to your computer when you start the scanner using the scanner icon on your computer.
The the way is to save the images to your memory card and transfer them to your computer using a memory card reader, then you can email these images as a file attachment in your emails.
Aug 26, 2011 | HP Photosmart C4180 All-In-One InkJet...
I have a canon MG5220 printer and unable to scan properly the messages I receive are saying Scanner turned off, disconnected from LAN, code 2,145,50. Printing pictures and all other printing jobs work...
Regarding the Cannon scanner error 2145,50. I note you have tried to fix this, but failed. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it.
I know, I had that problem. I am a retired elctronics design engineer.
Mar 07, 2011 | Canon Pixma MG5220 InkJet Printer
Computer says it cannot initialize the scanner
insert installation cd adn perform add a device. or if your pritner is connected to bluetooth it will not scan. as blue tooth signal is not strong enough to scan from pritner to computer. it works on some but don't work on all blue tooth
Dec 15, 2009 | HP Photosmart C5280 Printer
Scan from printer through router to pc?
You will need to use the TWAIN software for the printer. From the computer you will be running the scan options thru the TWAIN software. Then the scan files will be pulled from the printer back to the computer. Running scan options directly from the printer will give you the option to print the scan files or send them to a memory card if your printer has a slot for one. If the scanning software is not installed on your computer then you will need to download it from the manufacturer's website.
Sep 22, 2009 | Dell 1815dn All-In-One Laser Printer
There is no "Scan to Computer" option on my printer
Hi
It was my solution which was sent as clarification request.
Choose "Scan&Print" . It creates a file and saves. you have to find the location by doing a search.
luciana44
Aug 30, 2009 | HP Photosmart C6280 Printer
My kodak scanner won't scan but will print pictures
connect ur printer to ur computer and then try to scan any document or plug in any memory card and then press scan .it will ask u to save the file after scanning, save it on computer. ur issue will be resolved
Jul 20, 2009 | Kodak ESP 5 Printer
Memory card info wont transfer onto laptop from printer
I found another memory card and put that into the printer. The wizard came up immediately. I then replaced it with the first memory card and it worked as normal.
Mar 30, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Wanting to scan from scanner to computer
this happened to me too. i don't know how to fix it on the printer, but i scanned it through the computer. i went into the hp solution center, went to the scanning section, and told the printer to scan it from the computer. it worked fine. that way you don't have to save it to a memory card or anything. they went to the same folder all my other scans go to.
Jan 13, 2009 | HP Photosmart C4150 All-In-One InkJet...
My new hp photosmart c6250 will not print to my computer. the menue only gives the option to reprint or scan to memory card
I reinstalled the program and will control the printer from my computer. The scan menu still does not say, 'scan to computer', as the basic guide book says that it should.
Jul 17, 2008 | HP Office Equipment & Supplies
Problem scanning pictures
Check your documents folder under My Scans. I found that my scans were going in there. I had to open them to put them where I wanted them.
I also have the problem of the missing line up upload to my computer. If I restart the computer with the 6280 on the line reappears and I can scan what I want. I have asked HP what the problem is with no real solution. They seemed to think that since it works after restarting the computer that the problem was solved. The option shouldn't disappear from the screen at any time, but I guess I'm stuck with restarting the computer every time the problem comes up. Hope this helps.
Jun 30, 2008 | HP Photosmart C6280 Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
15 people viewed this question
Seeker5211
Seeker5211
