Question about Abit VA-10 Via KM400 AMD (DSABVA10) Motherboard
Computer will not turn on when I push the power button. The red light is on to show that there is power to the motherboard.
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Oct 04, 2009
2 Suggested Answers
antiochpc
  • 1314 Answers
SOURCE: Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Posted on Jun 21, 2007
The red light on the motherboard is flashing
Remove any drives and then power on, if nothing displays, replug your memory card,processor and dedicated video card if there is any. Lastly reset your bios, just remove the button shape battery and then place it back.
Thanks for using Fixya.
Jul 28, 2010 | Abit A17 Guru Motherboard
Acer wont power on
If the computer doesn't power on what-so-ever, it may be your power ribbon. I have the same issue with my Dell Inspiron 15.
The power ribbon on your motherboard connects to the power button on your laptop which obviously turns on your computer.
That may have been damaged. I suggest taking apart your computer and trying to find out the issue from the inside. (Or, if you don't know how turn it in to a technician.)
Nov 12, 2017 | Acer TravelMate 223XV PC Notebook
Computer will not turn on by outside push button. When it is plugged in and looking at the motherboard there is one green light on the board and thats it,if I push the test button on the power supply a red...
You can remove components from the pc and try to switch it on and see if it works.
eg.I would try a different power supply.
Then try different ram,
Then disconnect the Harddrive
If when you remove a component the pc starts, it's that component thats the problem
Dec 20, 2009 | Intel Motherboard
Acer Aspire Computer Does not Turn on
The light you are seeing usually is a sign that the battery is discharged. Although you say the battery shows that it is fully charged, it is possible that the battery is fully discharged or defective. You should disconnect the battery from the pc and try powering on with the ac adapter. Although no way to per say "force reboot," removing all power sources (ac adapter and battery) should in essence reset the motherboard.
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
My computer does not boot
No bios no post and no power lights on disk drives means hardware problem.
Either call a technician or try the following if you feel you can do it yourself, beware , there is always risk of damaging your PC on DIY.
unplug the computer, open PC and remove all plugs and internal and external devices, leaving only a minimal set of devices.
Start the motherboard with only Power adapter , one RAM module, and video card and screen connected. Unplug all disks and external devices, remove all pci cards.
If it still does not start take it to a repair shop, you may need to replace power supply, motherboard or ram.
Sep 17, 2008 | Computers & Internet
No power
check ur smps and power connector Mother board ok
next power switch for on/off ok check front panel byy
May 17, 2008 | Intel Motherboard
TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Jun 21, 2007 | Compaq (388746-001)...
Abit VA-10 Via KM400 AMD (DSABVA10) Motherboard Logo
78 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
