Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Service AGS message is on the heater - Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
  • 8,404 Answers
Look here:
http://www.jandy.com/html/productsupport/
I hope this leads you to your answer.
Alternataively, you could contact your local distributor.
Posted on Oct 04, 2009
I have a Master Temp 250 pool heater that shows an AGS error on the back of the board. The heater runs for about 20 seconds then shuts off, any ideas?
AGS = Auto Gas Shutoff...
What is happening is the heater is monitoring (or sorta, by reasons difficult to explain here) Water Flow and Water Temperature. In this case, the AGS is triggered by a low water flow, or high Incoming Water Temp.
High internal water temp = triggered AGS.
If you have and can confirm, PROPER water flow, water temp coming into heater is Lower than 104°, then it is possible you have a faulty AGS.
But in most cases, it's only doing its job. Locate the reason for the fault, or why the AGS Switch turned the heater off.
Jun 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
Laars LX 250 AGS Service error. Burners ignite the go out.
if connected 120 volt switch red and black wires its not rectification
Nov 17, 2012 | Jandy Laars Lt 250,000 Btu Heater
What does service ags mean on a LAARS LX pool heater?
AGS stands for Automatic Gas Shutoff. This means the heater failed to sense a flame or flame rectification. When this occurs, the the gas valve will close as a safety precaution. The heater will have to be reset to get another call for heat.
May 18, 2010 | Jandy 131K BTU LAARS AIR ENERGY HEAT PUMP...
Service light and ags light comes on after a minute or two
I had this problem. Jandy ended up replacing the burner from day 1 with the heater (LT400 propane). It was a manufacturing defect. Of course it took 5 trips from the "warranty" company to not fix it before they finally punted to Jandy. Then, there's only one Jandy service rep from VA to ME (I'm in PA).
Jan 27, 2010 | Jandy Laars Lt 400,000 Btu Heater
I have to reset the heater several times before it lights. I get the "service" and "AGS" lightgs flashing after it tried to light. Once it lights it runs fine
AGS MEANS TH EHEATER IS NOT FIRING CHECK YOUR GAS VALVE IF OPEN THAN CLEAN THE ORIFICES WHERE THE GAS COMES OUT AT THE GAS MANIFOLD
Oct 30, 2009 | Jandy Laars Lt 400,000 Btu Heater
Jandy lx250 heater is giving me service code ags
AGS automatic gas shut down
which means you have ignition failure, which can be from low gas pressure, or volume. if the heater fires then goes out the signal is not going back to the control module check all wiring.
Jun 16, 2009 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
The AGS "call service" light is on. Why?
AGS is automatic gas shutdown,
can be caused by problems with pump pressure, or low gas supply pressure .
Jun 06, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
934 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
