Cannot turn the dial to set the cycle and I cannot figure out how to pop off the plastic dial...it is stuck and won't let me even start the washing cycle.
  • Sassy6 May 11, 2010
    need make and model to help you. look for model around the opening of the tub where you put the clothes in at the back.
    President:
  • 1,304 Answers
The center of the dial should pop off when it does you will see a clip holding it to the shaft
Posted on Oct 05, 2009
Asko washer W6324. Ran two loads with no problems. These used the SANI setting (wish I could control the water temp by temp settings and not fabric descriptions). New load of delicates. I set it to woolen...
Try to press the start/stop button for at least 3 seconds. This should reset the started cycle, and you can make a new choice. If this dont help, it could be a faulty control board
Sep 29, 2013 | Asko Washing Machines
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Aeg lavamat 54600 won't begin cycle
check your pump down at the bottom of the machine take the bottom plinth off the plastic that runs along the bottom of the machine once off you will see your pump undo the plastic screw and get your self a towel and a small and big bowl there will be a lot of water so when you have took the screw out start turning the pump cap very slowly and when you have filled the small bowl close it and keep repeating it till all water is gone then take it right out if its stuck then pull it clean it out and put back together don't for get to turn your machine off be for doing any thing ok hope i have helped if after you have done the pump and the machine still do the same thing then its programmer ok
Nov 02, 2012 | AEG Washing Machines
SPEED QUEEN WASHER WON'T ALWAYS AGITATE
see this causes:
Lid switch
test for open or defective use the DVOM OR VOM
Motor coupler
COUPLER wears see the diagram
Belts
broken or worn replace
Clutch
clutch worn replace
Drive motor
bearing and winding burn in one directionor defective by overheating
Drive pulleys
drive pulley frozen or worn replace
Transmission
broken gear or worn
Agitator
can be worn too replace
Jun 21, 2012 | Washing Machines
Maytag LAT9635AAE won't start wash cycles
you can try to check the water level sensor Assembly this unit controls the fact that your washing machine will not wash until the proper water level is reached, this unit has a rubber hose attached to it and a wiring plug or connector for the electrical power to activate the motor.
Jan 10, 2012 | Maytag Washing Machines
Danby Dishwasher stuck in drain cycle after wrong soap use
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Dec 10, 2009 | Danby DDW1805W Designer Series...
Kenmore 26942503 washing machine cycle dial too loose
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26942503+
See the section on the control panel.
There are clips under the control panel that will pop loose is you use a thin putty knife to push on them from the front. Then the control panel should swing up.
Oct 12, 2009 | Kenmore Washing Machines
Kenmore washer Heavy Duty (70 Series) 1985-1989
behind the knob that you use to set the water level is the level control it should have a n adjustting screw to set the water level(you can set it where you want)
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Hotpoint bwm129 gets stuck mid cycle and dial does not move round
YOU NEED TO ESTABLISH IF YOU ARE USING A HOT CYCLE IF THAT IS SO YOU MIGHT HAVE E PROBLEM WHERE THE ELEMENT IS NOT COMING ON THEREFORE THE THERMOSTAT WILL NOT FUNCTION RESULTING IN THE TIMER REMAINING STILL.YOU NEED TO CHECK THE ELEMENT IF THATS THE CASE.IF YOU ARE USING THE COLD CYCLE AND IT IS STUCK ON THE SAME POSITION FOR A LONG TIME YOU MIGHT HAVE A FAULTY TIMER BEST YOU HAVE IT REPLACED IF THAT IS THE CAUSE.LET ME NO IF YOU NEED ANY MORE ASSISTANCE.GOODLUCK.MOHAMED
Sep 15, 2008 | Hotpoint BWM12 Front Load Washer
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
