Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Which sanitiizing system is better for hot tubs. Using the bromine powder everyday or the 2 step with the liquid and daily tablets in a floater?
    President:
  • 1,167 Answers
Hi buddy the bromine tablets if not maintained propally can lead to equipment damage which will be a high cost so use bromine liquid/powder which is the best use it daily buddy
Posted on Oct 04, 2009
How to clean a whirlpool bath tub
There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
This should do the job.
Pure Spa Whirlpool Bath Spa and Hot Tub Cleaning Kit
Nov 17, 2015 | Jacuzzi Whirlpool Cetra Whirpool Drop-In...
Is there anything on the market to replace chemicals on a new hot tub
Drain the water weekly. IF you really want to dish out the money you can get an Ultraviolet sanitizer or even an ozone generator but those are made to work with chemicas like chlorine or bromine, not stand alone, also for pools. And even then you would have to manage the ph somehow and that can only be done by replacing water or some kind of acid. Chlorine tabs now a days usually take care of both trichlor being slightly acidic for such a small body of water takes care of both. If you have some kind of chlorine smell from your spa and you are not sitting right next to a chlorine floater then you have a problem with the chemical balance and is a byproduct of chloramines.
Nov 08, 2015 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a floater for my hot tub and add approx. 2 little pucks as required, yet when I take my readings it shows no chlorine present at all!
Do you smell the chlorine on the puck itself or actually coming from the hot water? If you have to put your nose up to it it sounds like the puck isn't dissolving enough in the water (maybe they put too much binder in the manufacturing mix). You know you can use regular household bleach to put chlorine in there. Put a couple of cups in the tub and take a reading. That bleach is a lot cheaper than the powder or the pucks and works just as well
Feb 26, 2015 | Pool & Spa
How do you use the tub clean?
Read these instructions carefully before
beginning the TUB CLEAN cycle.
Open the door and remove any clothing in
the wash drum.
Open the dispenser drawer.
Add liquid chlorine bleach or tub cleaner.
Some powder or tablet tub cleaners which
are manufactured for this purpose can be
used.
(NOTE : Do not add any laundry detergent
or fabric softener to the drawer when using
TUB CLEAN.)
- If using liquid chlorine bleach
Add liquid chlorine bleach to the bleach
compartment of the drawer.
(NOTE : Do not exceed the maximum
fill line and do not pour undiluted liquid
bleach directly into the wash drum.)
- If using powder cleaner
Remove the liquid detergent cup and
add powder cleaner to the main wash
- If using tablet cleaner
Add tablet cleaner to the wash drum
directly.
(NOTE : Do not add tablet cleaner to the
drawer.)
Close the drawer and washer door.
5
Select TUB CLEAN and press START.
NOTE : It is recommended that TUB CLEAN
should be repeated monthly.
If mildew or musty smell already exists, run TUB
CLEAN for 3 consecutive weeks.
After TUB CLEAN is complete or when the washer
is not used, leave the washer door open for better
ventilation and drying inside of the washer
Jul 05, 2014 | LG WM2701HV Washer
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
ITS NOT REALLY CLEANING
I cannot tell you why your tablet doesn't clean well not knowing your machine, but having tried several types and brands (liquid, tablet, powder) I have found that the powder cleans best in my machine. Maybe it is something to do with dissolving or your water is not hot enough --possibly tablets work best in certain machines and not others. I don't have any interests behind my advice, but Cascade Complete was the one recommended to me and has become what I use exclusively. But I am willing to try others as technology develops.
May 12, 2010 | Zanussi 24 in. DA6141 Built-in Dishwasher
Using powder 1/2 recommend amount. there is a continual build up of powder in the dispensing cavity behind drawer. how do I prevent this am having to clean with toothbrush daily
Hi
When you start a cycle, does the machine take a long time for it to fill up with water.
If so, you have a faulty inlet valve. There is a rubber diaphram inside the valve which tends to tear over time.When this happens the water just trickles in. Therefore the soap/powder is not dissolved into the tub thouroughly.
Some powders also dissolve less than others, and using the machine on hot water cycle helps to dissolve the soap faster.
Regards
Ash
Nov 12, 2009 | LG WM-2277HW Front Load Washer
Does not wash well, does not use dishwashing liquid
Here are a few steps to solve your problem. First of all empty your dishwasher and pour in two cups of vinegar. Run the longest and hottest cycle you have. This will clean your machine.
Always run the hot side of your kitchen sink until the water is as hot as it gets and then start your dishwasher.
Switch over to a tablet as opposed to powder or liquid and just toss the tablet into the machine,
now you should be back up and running.
Aug 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Powder or Liquid
. HE detergent is a must for these machines first and foremost. as a genral rule liquid detergent breaks down better in cold water, so performs better in washers(cold water rinses). powder breaks down better in hot water which is why its reccomneded for d/w's.that being said i dont really mind which is used where so long as your not experiencing cleanig problems, at that point its when i reccomend using the appropriateone. whirlpool has now reccomneded a product called AFFRESH, tablets that can be used to clean out you frontloading machine incase of residual build op and/or odors.
Feb 28, 2008 | Whirlpool WFW8300SW
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
