Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
I am looking for an exploded view of the Poulan TE 40CXL for disassembly and assembly purposes.
  • 148 Answers
Use the "PARTS LOOKUP" button on the left and find your model by using the drop-down menus HERE.
Hope this helps.
Posted on Oct 04, 2009
Where where do I get a exploded diagram of my Poulan Pro blower model ppb 430 vs. also assembly. in diagram that would show me how to put it back together
Here is a source for the exploded views. Enter your model number as "PPB430VS" and chose your type number. This type number is the last of the serial number after the dash.
Poulan Parts Lookup by Model
Apr 07, 2015 | Poulan Garden
Replacingspringinpoulanhandel
I'd suggest going to Jacks Small Engines on line. Look up your saw by model and or serial number. Find a parts breakdown in their files...its all free.... and look at the exploded view of your particular saw. There you will find the correct orientation of the spring and related parts that have to be aligned to re install. There ARE NO directions, just an exploded view. It will help.
Sep 21, 2014 | Poulan Piston Ring Fits 2300av 2300cva...
Poulan Pro Chainsaw chain tensioner is junk -- chain now goes from tight to falling off in 1 cut. Model PP4620AVX. Looking for more foolproof mechanism!
Hammy if you scream loud enough Poulan may foot the bill for this.
Poulan “PP4620AVX” IPL (exploded parts list)
We are going to replace this page 2; item 70
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AVX-545103410-952802169.pdf
Poulan “PP4620AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047502.pdf
Poulan “PP4620AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 67; ChainBrake Assembly; $21.83.
You also need;
  • Item 68; Bar Mounting Nut; $0.56 each (need 2) and
  • “Engine Assembly” print; not illustrated; part number 545006011; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 18, 2010 | Poulan Pro Chain Saw 46cc 20"
Disassembly of poulan woodshark model p3314wsa to
This is an IPL for a Poulan P3314 (may not be your saw), It seems there are 2 different size hoses, I suggest you disturb only what is necessary, take a digital photo, then a small sample of both sizes to a local saw outlet. 12" of both sizes should be ample, ask for his guidance before you order.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008-P3314-530165402-952802026.pdf
Many also find this helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If not your saw try here (there are 3 "P3314WSA"s available):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The IPL can be used as a disassembly guide too, although you should not need disassembly beyond removing a cover or 2. Good luck with your project If I can be of more help you can reply below. HTH
Lou
Jan 28, 2010 | Poulan Garden
While trying to start the WT200, two washers and a nut fell out thru the vacumm tube.. When I put them back on and tighten the nut, impeller would not turn..
The exploded assembly shows the flat washer to be installed first and the curved (bellville) washer next. Then the nut last. Unless the impeller's index is misaligned, there appears to be nothing special needed.
Click HERE to see exploded view.
Hope this is helpful,
Dolf-
Nov 02, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
How do I replace the pull rope on the TE 475 weedeater? I went to start it today and pulled on the rope and it all came out.
How do I replace my pull cord on my weed eater TE 475? I have the parts diagram, I need to know where the cord attaches and what the steps are to rewind the pulley and attach the cord.
Oct 19, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Need to reassembly my fuel line could you please e-mail me the assembly instructions to look at.
Almost all Poulan models are listed here:
Poulan.com
Look around and find your saw. The IPL (exploded parts list) is only diagram I've found for part placement and routing. GL
Lou
Sep 06, 2009 | Poulan Garden
Throttle assembly
try www.jackssmallengines.com parts look up poulan 2500 they have exploded views of all parts this may help you will probably have to search arond abit
hope this helps
Nov 01, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
163 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
