Question about Kenmore 73952 Gas Dryer
Gas dryer heat is intermediate
Dryer will heat up first 5-7 minutes then flame goes out!! igniter tries to relite flame however does not work. you can wait several minutes turn dryer off/on every thing works fine about another 5-7 minutes!! igniter glows but no flame during process! exhaust vent is not clogged, you can feel plenty of exhaust on exterior of house. gas line not cinked going to dryer! nothing on inside of dryer interfearing with entry of heat!
dryer is a kenmore 70 series gas dryer!
  • 464 Answers
Does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Posted on Oct 04, 2009
Kenmore model#110.72702101 starts up,heats then burner stops won't relite
If what your seeing is that the flame starts out and goes off and a few later later the igniter glows but no flame??? then the cause of that is going to be the coils on the gas valve are weak and not opening. This tip i wrote explains what is wrong when a gas dryer starts heating but after a while wont heat. http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
GENE
Sep 13, 2011 | Kenmore Dryers
Dryer starts hot surface ignitor comes on gas valve opens i get a flame 5 mins flame shuts off hot surface ignitor repeats and tries to ignite no flame after unit is off for 20 mins to 30 mins off unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Kenmore 77632 Gas Dryer
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas comes on and ignites first time and after up to temp and flame shuts off it won't relite. the igniter glows but no flame
bad gas coils located on top of the gas valve.when the coils are on there way out they will do this,when they heat up they fail,when the dryer and the coils cool down they will fire.they let the gas in and the ignitor ignites the flame after 15 to 30 minutes they fail.let me know how you make out
May 24, 2010 | Kenmore 73952 Gas Dryer
Dryer gas ignites Runs for up to 5 minutes flame goes out
check the igniter to make sure it is glowing white and not orange. if it's orange replace it. you may also need the gas coils replaced.
Oct 16, 2009 | Hotpoint Dryers
Alantis Gas Dryer MDG7600AWW not staying hot or lit
All you need to do is replace those pesky intermittant coils
aab79a0.jpgI wote a short essay on this problem. To keep from being redundant I have it HERE
Mar 02, 2009 | Maytag Dryers
Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Feb 04, 2009 | Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Kenmore 73952 Gas Dryer Logo
467 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
