Question about Frigidaire GLGR331A Gas Dryer
My dryer squeaks as it drys - Frigidaire GLGR331A Gas Dryer
  • Frigidaire Master
  • 8,404 Answers
More than likely, the felt "bearing" on the front of the drum is causing the noise. You can clean it if you like - remove the top, remove the front to do so. While there do a thorough cleaning of the inside. You may also want to change the belt
Alternataively, you could turn up the radio a little to cover the squeek.
I hope this helps you.
a
Posted on Oct 04, 2009
    President:
  • 1,564 Answers
There are four drum wheels at the base of the dryer that, over a period of time and immence heat, get dried out and need to be sprayed with a good penetrating oil(not WD-40) and this should solve your problem. If there are no rollers then part of the front seal or the rear seal are worn and should be replaced. They generally wear at the 12:00 position because this is the highest level of strain on the drum itself. Thank you, Dana
My dryer makes a dragging sound when it operates, the unit heats and drys the laundry
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 30, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Our ggw9250pw3 Whirlpool Dryer has begun making an aweful grinding noise and a clanging sound. It still drys and the drum turns
heatman101
Mar 19, 2011 | Dryers
When I first start my dryer, it squeaks real loud for about ten minutes, then stops. It drys the clothes without any problems.
drum rollers/glides may be the idler arm, if is located next to the motor:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 23, 2011 | Dryers
Dryer makes load noise but still drys clothes
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 17, 2011 | GE DSXH43EAWW Electric Dryer
Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus Electric Dryer......Starts, runs and drys but has a REALLY loud squeaking sound
Your drum rollers is in need of lubrication.
You can lube them with a high quality machine oil like 3inOne oil.
Please rate me
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer "rumbles" while spining but still drys,why?
heatman101
Oct 25, 2010 | Kenmore Dryers
I have an 80s dryer that thumps and slows down somewhat, but otherwise drys.
heatman101
Oct 21, 2010 | Maytag Dryers
Dryer rotates and drys well, but makes a noise when reversing rotation. Makes more noise at the beginning of use, then subsides. What could be wrong? Belt, bearings? Can I fix or do I need an expert?
heatman101
fsjhgf
Nov 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
Jun 17, 2009 | Magic Chef CYG4000AWW Gas Dryer
Squeaking due to weight of clothing
When you need this kind of noise and there is no abnormal vibration, then it depends on the drive pulley that pull the belt.
If it depends on the weight, and you get vibration it can also depend on bad dumper pads.
Here you can locate dumper pads and drive pulley below the tub.
Both parts are serviceable, repair should not be expensive.
If you need to contact a repair service, you can use the number listed on the owner manual.
Sep 05, 2008 | Hotpoint NWSR483EBWW Electric Dryer
Frigidaire GLGR331A Gas Dryer Logo
116 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
