Burning smell coming from washer - Washing Machines
  • 464 Answers
Rubber smell like a belt or electrical smell. need make and model.
Posted on Oct 04, 2009
4 Suggested Answers
  • 1073 Answers
SOURCE: Frigidaire Washer machine with burning smell
burnt belt, tight center tub bearing, motor going bad, loose idler pulley spring, wiring issues at the motor, a lot of could bees
Posted on Apr 12, 2008
onthejob5130
  • 640 Answers
SOURCE: burning smell coming from washer
belt..than watch your pullys
Posted on Dec 28, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore washer has burning smell and smoke
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Washer agitates but will not spin. Burning smell coming from motor
The water pump could be stuck, or broken so the pulley on the pump is not spinning, while the belt is, which gives you the burning smell. Could also mean the motor is overheating giving you the burning smell. You will have to open the back and observe whats happening while its running. Just keep your hands clear while its working.
Feb 16, 2015 | Kenmore 98702 Stacked Washer/Dryer
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Maytag Atlantis washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
My whirlpool washer fills up with water, and then when it's suppose to agitate it does nothin and smells like something is burning. Is it fixable?
ya it is fixable as you feel some smell it may be some fuse burn out . check fot those things first. if fuses are fine some coils would have burned that would be the problem
Aug 06, 2009 | Washing Machines
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Apr 12, 2008 | Washing Machines
Burning smell
There are a lot of reasons could cause it. Best thing will be to open machine's service panel and to find out from where does this smell comes. Let us know with your results and we will see how could we help you.
Aug 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
521 people viewed this question
Top Washing Machines Experts
