Question about Philips Magnavox Learning Universal Remote
Tuning i have a hikona television and bought a set top box. I cannot get the television to tune in. It doesn't work. What must I do. I have put the tv onto AV and it just shows "no signal",
  • 3 more comments
  • Anonymous Feb 14, 2008
    i have a hikona portable tv and i dont know how to tune in the channels
  • Anonymous Aug 08, 2008
    Same as the others that the Hikona will not tune in.
  • Anonymous Aug 17, 2008
    exactly the same there any chance of getting an answer on here? im going to phone tesco they sold the bl**dy thing to me!
  • stuxxart Oct 26, 2008
    same as the others how do i find the solution on this site
  • lotadebz Feb 20, 2009
    I have the remote but no manual so dont know how to tune the tv.
I have a hikona 14" tv havew lost the tuning manual. Can you help!
Posted on Sep 14, 2008
Get universal remote for magavox codes?
Posted on Jan 01, 2008
Tuning AWA television with no remote?
Universal remotes don't do all the functions that a manufacturer remote do not for remotes in Australia
If you use a set top box tuner the TV will become the monitor and the box will become the tuner and use one of the rear or side video inputs and bypass the internal tuner and just programme the stb remote to set the TV volume to the desired level
The above link may have the remote you want but as I am in the UK the server blocks me
Sep 01, 2015 | Televison & Video
How to tune channels on a 14 inch RCA tv?
You need a good set top box, either Hi definition or standard Pal, to make any CRT Television work. These days, non digital TV do work well but they no longer accept analog signals, but when connected to a set top box that receives digital signals, the box converts the digitals signals to analo and sends then to the RCA inputs of your TV and not via an antenna connected to the set top box and the TV.
Sep 01, 2014 | Televison & Video
Why won't my nec tv tune to set top box ?
Unless your set top box has a digital RF out you have to use a SCART lead
Aug 09, 2014 | NEC NLT-22HD3 22 in. LCD TV
I have a Hikona combined 14" tv and dvd player,
Try going into your settings in the tv and try changing were the signal comes from and manually 're time sometimes works in pore signal areas and moving the aerial may help
Nov 28, 2017 | Televison & Video
I have a MXT Standard definition set top box model num: MSTB202SD. When I try to auto tune it comes up database empty, can you help?
The commonest cause of this problem is tuning the set top box when the aerial lead has become disconnected or is plugged into the wrong socket (should be in the rf in or antenna socket) . As part of the normal tuning process, all previous tuning info is automatically deleted and with the aerial lead disconnected you will then end up with nothing. Make sure the lead is properly connected to the aerial and tune again.
Another possibility is to go into the main tuning menu and select return to factory condition. This will force a main reset deleting all data and you will then have to work through the whole tuning process from scratch including, setting your State, setting the tv resolution (720p, 1080i etc.) If neither of these options work, and you are certain that the box is connected to a good signal, then the box may be faulty. Good luck.
Jan 02, 2011 | Televison & Video
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
We have a bush set top box with no instruction book. one channell Win (9)is indicating ''no reception'' We were told by a local TV repairer to re tune our tv. How?
You should not have to re-tune your tv as the set top box will be plugged in via a scart lead so its the set top box that needs to be retuned.
Go to the menu of the set box and select new installation under features or set up.
Hope this helps
Apr 09, 2010 | Televison & Video
No channels on the list
Be sure that you are on the "Tuner" input, and that if you are using a converter box, that you have the set tuned to the single channel that the box puts out. (In the US, that's either 3 or 4.)...accordianman
Jun 30, 2008 | Olevia LT32HVE 32 in. LCD Television
Universal tv remote control codes for a hikona tv/dvd combo
you have to set the code for TV alone, then code for DVD
Apr 24, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Jan 08, 2008 | Televison & Video
Philips Magnavox Learning Universal Remote Logo
879 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
