Question about Brother HL-2040 Laser Printer
Where is the toner reset button on the Brother HL-2040?
    Problem Solver:
  • 6 Answers
I think there is none. It will reset when you install a new cartridge.
Posted on Oct 09, 2009
I have a Brother HL 2040. I placed a remanufactured drum and toner into it. The Drum light keeps going on. From various sources on the internet, I learned that I am supposed to reset the white counter on...
Here is the drum counter reset procedure.
Good Luck and Thank You for using Fixya.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover.
Sep 25, 2010 | Brother HL-2040 Laser Printer
All the light flashing
Try this procedure as mentioned.if any mistake in trying the procedure then retry from first step again.so read it carefully and try it. Brother ML-2040 Toner Light Reset
When replacing the toner cartridge in the Brother HL-2040 with a new cartridge (compatible or remanufactured) the user may experience a problem with the toner light staying on, even with the new toner installed. The procedure below has worked for many folks, so give it a shot.
Open the front cover of the Brother HL-2040 and leave open while completing the following steps:
1.) Turn the printer off.
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your “low toner” light should be fixed.
------------- From Brother Service Bulletin
1. Open the Front cover
2. Press and hold the GO button
3. Power ON the printer while continuing to hold the GO button
4. Once the 3 LED’s are lit, release the GO button
5. Press the GO button 2 times. This will cause the LED’s to light solid
6. With the LED’s lit solid, press the GO button 5 times
7. Toner Life End will then reset
8. Close the front cover.
----------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Brother HL-2040 Laser Printer
How do I pull out the toner cartrige of a HL 2040
Front panel of printer (manual paper feed is in the middle of this panel) has tabs on the right & left and will fold out and down. The toner/drum is right inside. there's an opening in the middle to grab it and pull straight out. The toner will separate from the drum unit by holding a small purple/blue tab on the left side down, and then lift up and out. Reverse this when putting everything back. remember to shake the toner right-left to loosen the toner before putting back in the unit. To reset the printer, and with the front door still open, hold the GO-Control button down until all lights are on, then let go, close up front door. Power off & back on and you should be set.
Jan 05, 2010 | Brother HL-2040 Laser Printer
I have a Brother HL-2040 and the Toner light is on. I have replaced the toner but it still will not print. Can you advise if there is a easy solution to this problem?
Front panel of printer (manual paper feed is in the middle of this panel) has tabs on the right & left and will fold out and down. Remember to shake the toner right-left to loosen the toner before putting back in the unit. To reset the printer, and with the front door still open, hold the GO-Control button down until all lights are on, then let go, close up front door. Power off & back on and you should be set.
Nov 25, 2009 | Brother HL-2040 Laser Printer
How do I replace the drum on a Brother hl 2040.
I have 'reused' the same drum three times and still prints like a charm.
Open the toner door and pull out the toner/drum assembly. Take the toner off the drum tray. Use a alcohol pad or lint free cloth and wipe the mauve coloured drum to remove the excess lint and toner collected on the drum. Rotate the drum with the white gear and keep cleaning until the whole drum is done.
Put the toner back in the drum tray. Clean the corona wire by sliding the blue tab back and forth 3 or 4 times. Put the toner/drum back into the printer and close the door.
After the printer does the self test the drum light will cone on again so then you need to reset the counters.
Open the door again
Hold the GO button until all 4 lights are lit up
Release the GO button
Close the door
Printer will self test and should extinguish all the trouble lights.
Apr 10, 2009 | Brother HL-2040 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Drum light HL-2040 Brother
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
On older models
  2. Remove the drum and toner
  3. Press the Go buttom button until all lights are lit, (they come on one at a time) then release it.
Oct 14, 2008 | Brother HL-2040 Laser Printer
HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
BROTHER HL-2040 LASER PRINTER- TONER LED INDICATOR STAYS ON AFTER I REFILLED THE TONER
Dont recomend refills causes too many problems, like you are experencing, put in a real brother toner should fix problem.
great link to explain of lights on panel
Dec 18, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
445 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
