Question about Dryers
Creda drier cw622
Need to replace on/off button, but can't work out how to remove fron panel to get to it. Have unscrews 4 screws but it still seems to be attached at the dial.
    Problem Solver:
  • 4 Answers
Call an appliance repair man
Posted on Oct 04, 2009
Remove rear passenger door panel Mercedes ML350, 2005
Open crank window.
Remove cover for door handle and unscrew 2 screws.
Unclip SRS panel and unscrew screw.
Press door liner off bottom, fron and rear inner door panel with wedge.
Lift door liner up and out.
Unhook inner door actuator.
Unclip inner lock on door liner.
Remove lamp.
Sep 24, 2013 | Mercedes M-class Ml Ml350 Ml500 Ml55...
Door clip is broken, can i replace it?
Yes It's a relatively easy fix, turn off the power then just remove the screws on the inside around door and separate the panel, you will need a star head driver or a hex driver will work to. from the inside you can remove the wire harnesses then unscrew the door latch with a fillips driver and replace. This repair usually takes me about 10 minutes. Good luck
May 23, 2011 | Creda Dishwashers
Hi - I have a creda solarplus cooker (48349) - I wish to replace the 8 bar grill element with a 4 bar grill element - can you please advise me of the steps necessary to do same - yours michael clancy
It’s basically as simple as:
Turn off the gas supply to the range.
Turning off the mains power to the range.
Remove the back panel behind the grill.
Remove the 2 power connectors to the grill element.
Remove the earthing wire to the element screw terminal.
Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your range.
Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
Reconnect the earthing wire to the element screw post.
Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
Reconnect the power cables to the element.
Reconnect the power and check that the element works correctly.
Disconnect the mains power again and replace the rear panel(s).
Reconnect the mains power and recheck that the grill functions correctly.
Turn on the gas supply.
Oct 05, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
CREDA OVEN FAN NOT WORKING OVEN BARELY HEATING
As a first port of call, you can remove the fan by removing the inner back panel (4 screws) and taking the fan blade off (anti clockwise screw) The drop the fan out through the back of the cooker. If you apply WD40 to the two bearings you may get the fan going again. Otherwise you'll have to replace it.
Sep 29, 2009 | Creda C361E Electric Kitchen Range
How do I replace the belt on my Creda T620CW tumble drier
most credas you need a stretch tool to stretch the belt from drum to motor if there is no jockey pulleys good luck.
Sep 14, 2009 | Dryers
Creda Simplicity 1000 Washing Machine not heating water
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Thankyou.
Feb 09, 2009 | Creda W100FW Front Load Washer
Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Dec 15, 2008 | Zanussi TD4212W Electric Dryer
Not heating up
If fan is working o/k , then you need to replace the heater element.
This is located behind a removable panel at the rear of the oven compartment,
Undo screws and remove element .disconnect leads, be careful not to lose them inside, fit new element, fit cover back.
Plz rate this solution.
Tthanks, and merry exmas.
Nov 16, 2008 | Creda C362E Electric Kitchen Range
Krups XP7240, power button seems to be broken. How do I fix this.
Release and remove front panel pulling it up. Then remove two upper screws. Gently unfasten control panel cover, unscrew electronics, buttons etc. There is a plastic sprue which forwards pressing force down to microswitches. Probably sprue is cracked. Just glue it, add some more plastic to strengh it.
Oct 30, 2008 | Krups Small Appliances Espresso Machine
Tumble dryer Creda Smplicity T320VW
I am an authorized servicer for Creda and I can explain how to remove the front panel to change the belt. Email me at starztruck4u@aol.com if you still need help.
Mar 18, 2008 | Dryers
Dryers Logo
Top Dryers Experts
