Question about Kenmore Elite 45986 Front Load Washer
Cant get my washer back together.
I have a Kenmore Elite Calypso washer. Our sheet got sucked down and stuck underneath the calypso part. So I took it apart and got the sheet free, it ate it up pretty bad. As I was putting it back together. Tub Ring Assembly would not snap onto the hooks of the Tub. I have tried with all my strength to snap it back on but it just will not go. Even with only a few hooks in place I tried to run it but an CA error came up. The Washer is not spinning. The Tub Ring Assembly is too tight on the Balance ring. Any ideas?
    President:
  • 1,564 Answers
Make sure the rear seal has not turned in and become curled into the path of the rear ring on the drum.
Posted on Oct 04, 2009
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
An article of clothing went underneath the washng plate in my kenmore elite calypso washer. How do I get it out?
At the bottom take the cap off and you will see a bolt that needs to be removed then the plate comes off
Jul 17, 2015 | Kenmore Washing Machines
How do I remove a small part of ziper
You go buy a magnetic or three hook flexible retriever from your hardware store and go fishing down the side.
Or if the zipper is floating about loose you take the back off the machine after dumping the outlet hose into a bucket to drain off the water.
Tip the machine forward or backward so that the outlet hose from the drum to the pump is as near to the ground as possible then remove the clip retaining it to the outer drum and your zipper should be within grabbing distance.
Make sure you have an old towel underneath the hose before you crack the joint
Jul 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How to remove a small pice from uderneath a main washpla
Have you tried a shop vac with a nylon over the end of the suction pipe yet ? Usually works wonders.
Stops in the middle of rinsing...leaves some water at bottom-
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washer ate a sheet
the wash plate has a rubber seal all the way around the bottom even the smallest gap can grab clothes and pull the under only solution is replace plate
Aug 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer pulling clothes under agitator
The gap between the wash plate and inner basket has widened.
Part #WP285903 retail $65.75
Nov 05, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
160 people viewed this question
fordexpert
Mike Squire
Robert Rankin
