Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61 in
Randomly turns off for no reason. I can turn back on immediatly. Then it turns off randomly again after 3 min up to two hours.
  • 2G2G Dec 25, 2007
    I also have the same problem. The frequency of this occurence is increasing. My local service provider doesn't have a quick answer.
  • Farmer Ben Aug 15, 2008
    I had the same problem last year and Samsung replaced EVERYTHING on it to no avail. Fixya sent me a fix that showed how to make sure the switch on the lamp door was in the proper position when insatlled. It worked perfectly and so far I have had no other problems........I looked to see if I could find it..........sorry, but it was an easy fix...might look thru the archives.....
    Problem Solver:
  • 4 Answers
Mine started today any ideas?
Posted on Jul 23, 2008
  • nervouss Dec 01, 2008
    I have eventually called in the repairman on this and it's been about 8
    months since he has fixed it and the TV is still working fine . He
    told me this was a common problem whereby the solder neat the high
    voltage area on the board becomes cracked /weakened causing the voltage
    to fluctuate eventually causing the TV to shut off. All he had to do
    was reapply more solder to these high voltage points (near the power
    supply) and the Tv was fixed took him about 20 min cost me about $180,
    hope I can save you some money.
  • 579 Answers
Get on the phone to Samsung at1-800-522-7341.
You have one of the dreaded N series that is full of problems.
Even if you are out of warranty, they have been known to work with you.
Posted on Jan 01, 2008
Samsung HLN617W No Sound. As I turn on the TV, the speakers give off a "sputtering" noise that can barely be heard. After a while the speakers come on. But, what used to take five minutes (2...
Red light comes on but then the tv is playing but after about 3 hours it just goes out but I can still hear the sound then if I go back after about 4 to 5 hours if I turn it on it plays no problem. Now the lamp just went. I think before replacing the lamp maybe I should replace cooling fan also.
Jun 07, 2011 | Samsung HLN617W 61" Rear Projection HDTV
Ok the details, HLN617W replaced color wheel and bulb works. Tried the power - unplug reset and worked for about 25 mins then I turned it off after no problem. No here is my original problem, after turning...
I WOULD RECOMEND CHECKING YOUR CAPACTIORS (CAPS)ON YOUR BALLIST BOARD (THE ONE THE LAMP PLUGS INTO) IT'S ABOUT 3" X 8" IN SIZE DO NOT TOUCH THE BOTTOM OF THE BOARD!!!!!! YOU WILL END UP IN THE EMERGENCY ROOM. JUST LOOK TO SEE IF THE CAPS ARE BUBBLED OR BLOWN IN ANY WAY.
Feb 13, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
May 27, 2009 | Samsung HLN617W 61" Rear Projection HDTV
No picture but sound once it goes off there is 3 blinking lights
Most likely for this symptom is the lamp. If you'd like you could sit behind the set and have someone turn it on, you should hear the color wheel spin up and then you should hear the ballast try to fire the lamp, it makes a small arcing sound. If the lamp doesn't light the process starts over again.
Jan 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W Tantus 61" DLP occasionally will not turn on.
It sounds to me like you have an issue with the ballast not firing the lamp. It sound like you know to check the lamp, but there is no way to check the ballast, unless you replace it. The ballast is not that tricky to replace, but if you are not sure I would refer you to a technician to replace the part.
Jan 22, 2009 | Samsung HLN617W 61" Rear Projection HDTV
My Samsung HLP6163 tuns off randomly all evening
if you are able to simply turn it back on, then the problem is probably the lamp door cover switch. unplug the set, remove the lampdoor cover. the switch will be in the lower left of the opening. put the door back on while making sure that the switch lever goes down NOT UP. some of these sets came through with the switch up. it works for a while but then the little arm starts to warp and it causes your problem
Dec 14, 2008 | Samsung HLP6163W 61" Rear Projection...
Hello
Problems with the lamp door detector switch. Try jumping out this switch and running it for a while. The switch is the small switch with the blue rocker arm activated by the tab on the lamp door panel.
Jan 31, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 61" HDT5087S/HL
How old is the unit?
ever replaced the lamp?
Sounds like a major power supply failure
Hope you are under warranty
Samsung has lots of problems with this technology
Here is their phone for executive customer relations: 1-800-522-7341
Dec 30, 2007 | Samsung HLN617W 61" Rear Projection HDTV
TV randomly shuts off
when it shut off, are you able to simply turn it back on? or do you have to unplug it? also are any of the leds on the front on or blinking
Nov 29, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Turn off by itself
1)Lamp
2)Color wheel
3)Lamp Ballast
4)Complete engine replacement
Locate a servicer who has all parts possible on board his truck.
Ask what a diagnostic service call/repair would cost.
Oct 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
148 people viewed this question
Jerry Greenberg
Jerry Greenberg
