Question about Samsung HT-WX70 Theater System
Samsun HT-WX70 overheating and shutting down
I have the same problem. I have removed the case and with a small house fan blowing directly down on the area where the fan is running the unit will stay powered up and running indefinetly. Is this the exhaust fan or is the unit simply overheating beyond what the exhaust fan can handle. I was led to believe that an exhaust fan runs pretty much at the same pace until it dies, no slowing down, etc.
Thanks
The receiver in the Samsung ht-wx70 system that I have runs fine until all of a sudden I hear a loud bang and it shuts off. If I touch the unit, it is burning hot. I took the fan out and it works when I attached it to a 9v battery. Is it the fan or another problem that I should be looking at.
Posted on Jul 18, 2011
Check fan shut down
You fan is damaged , please replace it to prevent your device from overheating
Jan 11, 2011 | Samsung HT-WX70 Theater System
I turn on my system and it works ok for a couple of minutes. Then it started showing "fan check" for another minute, then shuts itself down. Is it the fan? How can I check that?
To answer your question, yes, it is the fan. There will be screws holding the top cover onto the unit; remove these, and find the fan(also remove any dust you find inside, as this also could render the fan useless due to airflow problems). Make sure it's not jammed or clogged or anything such, and plug the unit in, turn it on, and make sure the fan turns on(in some cases, it waits a maximum of one minute to do so.) If it does not turn on after one minute, then a new fan is needed. Any fan with the same size and power connector will do.
Dec 04, 2010 | Samsung HT-WX70 Theater System
Fan check flashes, then the unit shuts off. I found a replacement fan, will changing it solve the problem?
I am unsure if replacing the fan will work, but to test it, put a vaccum cleaner near to the fan, the rush of air should keep the fan spinning and fool the sensor, see if the unit then powers on, if it does then you know the fan is the faulty item.
Mar 02, 2010 | Samsung HT-WX70 Theater System
Powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Jun 30, 2009 | Samsung Audio Players & Recorders
Samsung ht-wx70 shutting off for protection
The word PROTECTION means that the cooling fan is defective. it needs to be replaced.
Call 1-800-7267864 (SAMSUNG) and they can repair it for you.
Hope this helps!
Jun 30, 2009 | Samsung HT-WX70 Theater System
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
HOW DO YOU RESET A SAMSUNG HT-WX70 HOME THEATRE SYSTEM?
According to the instruction manual you turn off the unit and press the Stop button on main unit for at least 5 seconds. Didn't help me with my problem (shutting down for no apparent reason) maybe it will help you with your problem.
May 06, 2009 | Samsung HT-WX70 Theater System
SYSTEM SHUTTING OFF
Sure for helping,
If there is a power problem means it will not turn on man,
so kindly check with the power cable, there might be problem with the power cable thats why it is switch on and there after it switch off,
so to resolve your issue you please change the power cable and if you find still problem you please contact once again i will give you the final solution for that ok.
Mar 26, 2009 | Samsung HT-WX70 Theater System
No Surround Sound in Aux 2 mode
genarally tv output contain two signals.(steereo).it dosent have surrund output.thats y its not hearing surround sound from your system.
Jan 07, 2009 | Samsung HT-WX70 Theater System
System turns off by itself
My unit said "protection", "goodbye" so I opened it up and found a capacitor to one of the speakers had blown, right by the fan. It's a 35 cent part and a simple solder job. The hardest part was getting the face plate off the dvd tray so I could get to the circuit board.
Apr 01, 2008 | Samsung HT-WX70 Theater System
Samsung HT-WX70 Theater System Logo
418 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
