Question about External Drives
USB DRIVER I need Windows 98SE compatible driver for my usb card reader
The Machine
  • 788 Answers
SOURCE: driver for USB key
Get the driver here: make sure to pick the right version of for your flavour of Windows 98, you most likely have the SE or Second Edition version.
This one might also work:
Posted on Jun 17, 2008
  • 56 Answers
SOURCE: SanDisk U3 Smart Cruzer 2GB USB Flash Drive
Here's the manufacturer's driver download site. Find the right product and operating system here:
Posted on Jun 11, 2009
SOURCE: Windows XP and VISTA Driver for Iomega Floppy plus
I found it elswhere --- in my Driver backups!!!!!!!
Posted on Nov 04, 2009
  • 12 Answers
SOURCE: my Corel Paint Shop Pro Photo X2 no longer
Go into your controll panel and go to Add and remove programs. Once there Look for your software,"Corel paint shop pro x2" You should have an option to change or remove it. We want to change it. If you can change it then tell it to repair and do as prompted. If that option isent avalible simply reinstall the software.
Posted on Nov 23, 2009
  • 1768 Answers
SOURCE: Windows 7 doesn't read my Dynex usb 2.0 card reader
1. You have to see if the program is compatible with the Windows 7 operating system.
this is possibly due to drivers that the Windows 7 doesn't have in the "cab" files.
this manufacturer of the Dynex is your next step for a Windows 7 driver set.
Posted on May 29, 2010
  • 88 Answers
SOURCE: i have a dynex usb mini memory card reader/writer
Plug the dynex card reader into your PC, insert the supported memory card type in the device. the computer creates a removable disk you can access from Start->Computer and then it will be listed as probably an E:\ or an F:\ or similar. Double click on the drive and then you can copy and paste anything you want into or out of it.
Posted on Jun 15, 2011
0 characters
1 Points
Driver icon
Most USB media card readers are plug and play. Plug into USB port, insert media (SD card, or whatever) and it will come up in Windows explorer as a drive and/or will bring up a box giving you options of what you'd like to do.
Jun 21, 2013 | Dynex Internal USB 2.0 Multiformat Media...
D_5300 software i have lost the cd
1. Follow this link for the Dynex drivers: Although this page is for the Dynex 6-in-1 USB 2.0 Mini Memory Card Reader, it should work for your 5-in-1 Reader. Post back here if it doesn't.
2. Click on Windows or Mac under Drivers, Firmware and Software.
3. Download file.
4. Open driver installation package and install driver.
5. Restart computer if necessary.
Thanks for using FixYa.
Mar 07, 2011 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
May 29, 2010 | Dynex External USB 2.0 Multiformat Memory...
I need to know how to use the Sandisk card reader. can u give me instructions?
You should be able to plug the device in. Most operating systems will recognize the device and treat it as new hard drive.
Are you getting a request for a driver? If so, first let Windows look for the driver.
May 22, 2010 | SanDisk Extreme USB 2.0 Memory Card Reader
How do i save my documents to ubs drive.
Please put ur memory card into card reader.
connect the card reader to the USB port of ur computer.
Now u can use ur memory card like Pen drive.
If the solution is working please vote for me....!!!!
Feb 19, 2010 | SanDisk 4GB microSDHC Memory Card
Memory Card
Do you have the driver utility cd for your card? try installing the driver from that even if it is not a windows 7 driver. You can always get an external card reader with usb interface if all fails.
Sep 02, 2009 | SanDisk 4GB microSDHC Memory Card
Is there a driver to allow sony micro vault 2.0gb on win 98?
Specs say it is compatible with Windows 98 SE. Also says no drivers are needed for it. Make sure your plug 'n play is enabled on your computer. Once it is enabled just plug the drive in & Win 98SE should install it. If it does not work then try a different usb port as maybe a port is bad. Hope this helps.
Jan 26, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
I am running Wondows SP Professional with all the latest updates installed (inc SP3). I have a Sandisk Imagemate 5 in 1 card reader and a Microdia Flashmover. When I put my SD Ultra II 8GB card in either...
Make sure that the Generic USB Device is in the safely remove hardware dialogue then try to install.. or the problem may lie in the face that your usb in not compatible with that specific card...
Jan 07, 2009 | SanDisk ImageMate 12-in-1 USB 2.0 Card...
How to download a driver/disk for my SanDisk Imagemate 12 in 1 USB 2.0 card reader
For cardreader you don't really need a driver for it , that should be a plug in play when you connect it to your pc because it function like a flash disk that the OS can automatically installed driver for it.
May 12, 2008 | SanDisk ImageMate 12-in-1 USB 2.0 Card...
External Drives Logo
202 people viewed this question
Top External Drives Experts
Brian Sullivan
Brian Sullivan
Are you an External Drive Expert? Answer questions, earn points and help others
