Question about Acer Computers & Internet
My acer monitor stop working, no sound or picture. Power cable is connected. Whats wrong?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Dahta_1, Sounds like the switchmode power supply has gone into what is known as "SHUTDOWN" mode to save it from having a catastrophic nonrecoverable failure. You failed to mention the AGE and /or approximate total "ON" hours this lcd has on it. Need more info to give a good reason for the failure of your monitor. I'm louie 12 fix on fixya or lmistyrel@aol.com Bye for now
Posted on Oct 04, 2009
Proscan tv power light blinks red and won't turn on, it normally is solid red when off and turns blue when on. whats wrong?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Aug 28, 2014 | Proscan 42LA45H 42 in. LCD TV
No picture on acer 19inch monitor
Disconnect all cables including power.
Wait 5 minutes.
Connect ONLY the power cable.
Does it come on?
If not, take it to a shop.
If it comes on the the source cable or video card is the issue.
Apr 05, 2014 | Acer Computers & Internet
Acer V173 with flashing amber led. No picture. cable good. other monitors work at this connection.
I have this same problem. Blinking amber Light and no display. on close examination I am seeing the video image attempt to come up, but with no back lighting. I think there is a power supply problem. I will post again if I learn more.
Feb 24, 2011 | Acer V173 b Monitor
Screen will not come on
Failed DC filter caps in the power supply, that will be the first place to look, read more below and look at my picture albums of ACER monitors.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jul 03, 2010 | Acer ETBV3RPB01 17 inch Monitor
The color on my monitor is changing by itself... going blue yesterday and red today? whats up?
Sounds like either your monitor is about to break or that there is something wrong with the connection between your computer and your monitor (something wrong in the cable). Next time that happens, try to move the cable connecting your computer with the monitor. If it fixes it, you better go buy a new cable.
Dec 03, 2009 | Acer Value AL1703SM 17" LCD Monitor
Acer Aspire 5100
Sounds like the power jack is loose if you have to hold it in a certain position. As for the screen your inverter might be shot. Try connecting an external monitor to your laptop and see if you get a display.
Sep 08, 2009 | Acer Aspire 5100 Notebook
Shadows
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Feb 07, 2009 | Acer X193W LCD Monitor
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
The monitor turns off and on repeatedly.
does sound like a power supply issue... they are fixable but it's somewhat involved.
Robert
Aug 28, 2008 | Acer AL1715 17" LCD Monitor
Computers & Internet Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
