Question about Dryers
I have an old Kenmore dryer, but I don't know the model. The dryer tumbles, but does not heat. I checked the gas line and it's turned on, and I'm not too sure how to check the air flow or the heating element.
  • Sassy6 May 11, 2010
    is it gas?? if so there is no "element". check around the opening where you put the clothes in for the model. if it's gas you may need an ignitor.
    President:
  • 1,304 Answers
Put your hand where the exhaust comes out of the building you should have a very good air flow from there
no matter what model it would be the same ignitor
without the model num i caNT REALLY HELP YOU GET INSIDE
Posted on Oct 05, 2009
Kenmore elite model 11070092990 dryer tumbling but not heating unplugged and started again-still not drying
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 13, 2011 | Kenmore Dryers
My kenmore is 21 years old it is still tumbling but has lost its heat to dry
heatman101';
May 24, 2011 | Kenmore Dryers
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
My kenmore dryer modle # 9758920 tumbles but won't
ther is heat fuse on the fan unit and the heat unit check them and then you good :)...take power off first!!!
Dec 31, 2009 | Whirlpool LER5636P Electric Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Just moved, dryer won't tumble with a load. Error code PF
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Dryer won't heat
Hi! donj56
There are a lot of challenges in checking the electrical system. If this dryer has a traditional timer it is best to find the circuit diagram included inside the dryer. Consult the diagram and make sure you have the same voltage on the input of the timer and then on the circuit feed to the igniter. The case is a good ground so you do not need to connect to the Neutral. Let me know the dryer model number? Is the dryer in a high humidity environment? Also, how old is the dryer?
Oct 30, 2008 | Kenmore 74602 Gas Dryer
Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
Aug 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite gas ddryer model 72062--No heat
Check the glow coil ,if its not glowing run a test for voltage when its heating ,should be around 117 volts.check thermal fuse.
Please Rate This !!!!
Aug 10, 2008 | Dryers
Dryers Logo
50 people viewed this question
Top Dryers Experts
