The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
The most likely problem is the magnetron, also the high voltage capacitor and diode can be a factor. If the magnetron proves to be the issue you are further ahead replacing the microwave oven.
what this mean it that your wave has develop a disconnection problem internally from the wire what you will have to do to fix up your wave is to unscrew your wave then trace the wire down to the element (heat provider) it is silver in colour please if there is no disconnection in it then it means that the element has gone bad then you will have to make a change of it with a better one you can get it in the store please make sure that all form of power supply is put OFF before you can carry out this function.
Ok, if this unit has stopped heating, this will confirm a major fault within the Magnetron. this device is responsible for the heating affect and, you will need to replace this damaged part in order to restore proper heating functions in you microwaveoven.
Most likely is the magnetron that failed. This is very common problem with microwaves.
Check the user manual under warranty, sometimes the magnetron has 5 years warranty.
