Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
My Hoover steam vac dual v's brushes will not spin and the square that the peg goes into wont spin either. There is suction but it is making a loud noise.
  • Malisa Suarez Jun 30, 2012
    We had the exact same product about four months after purchase. It was the gears weren't spinning. The problem was covered by the warranty and we had to send it off to their service center. That has been a real pain in and of itself.
  • 691 Answers
Sometime when the brush is not turning their are less resistance to the motor, so it will turn allot faster than normal. The turbine gear assembly which connected to the brush assembly probably broken, all the gears are made out plastic and they can easily break,strip or worned over period of usage. the assembly cost around 20 bucks and it not that hard to replace and it not that hard to take it apart, just remember what goes where. I wonldn't surprise when taking the vacuum apart as you observed closely and inspect the brush unit and the turbine gear assembly you might easily spot what broken and need replacing. hope that help some; and if you don't want to fiddle with it, your local vacuum repair guy can probably do it for less than 40 bucks. you can go on-line vacuum parts.com
Posted on Oct 04, 2009
    Sergeant:
  • 316 Answers
Sounds like you have it jammed
  • 458 Answers
REPLACED TURBINE AND GEAR ASYY
Spinscrub loud brushes don't spin
Most models have a screen under the machine or behind one of the clear covers on the front. If the screen is clogged it will restrict the airflow.
Make sure the brushes will spin freely by hand.
Oct 06, 2017 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes stopped turning
check the drive peg that turn the brushes it may have broke and needs replaceing this link is for the manual it will show you how to get the brushes off.
http://hoover.com/file/670/
Aug 11, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
The Hoover steam vac dual v does not spin its brushes and I dont know how to dismantel it to view the belt .
There is no belt on the steam vac - it operates on air flow. Remove the brush and insert a flat screwdriver into the square hole. If it does not turn, the turbine has seized up and must be replaced. Remember that the brush will not turn unless the lower tank is in place, and the handle is tilted back.
Jan 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hoover stean vac dual with 5 brushes
I think this is the same unit I have, I might have a couple of solutions. No, there is not a belt that turns the brushes and there is not a fuse.
First of all, make sure the brushes have been clicked into the machine properly. The entire plastic housing unit for the brushes can be removed by pulling on the casing gently. It should pop out. Make sure the pegs and clips line up with the holes in the machine when reattaching the brushes. You should hear it click when they are on properly.
If the brushes are attached properly and they still won't spin here is another possible solution. This happened to mine.
The plastic pegs on the housing unit for the brushes might have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you.
Aug 30, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes will not spin while locked in machine..
I have the same problem and think I know the solution.
The plastic pegs on the housing unit for the brushes have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
I hope this helps you. Certainly is cheaper than replacing a motor or machine.
Aug 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
My Hoover steam vac has two small springs that have come loose.
How do I replace the turbine? How do I remove the casing to get to the turbine? I do not have the manual anymore.
Dec 10, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Problems with the Hoover Steam vac Heated carpet cleaner
The first thing to check is the filter on the inside of the lid to the recovery tank, if it is all of the way up to the top, it can cause variouys problems, it should have a 1/4 in gap from the top. The other thing is the turbine, that is what drives the brushes. If the brush block is ok, then most likely the turbine is bad and will ahve to be replaced. Part # for the turbine is 43191006 and sells for about $60.
Nov 18, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
1,026 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
