Question about AOC Envision L32W461 32 in. LCD HDTV
Blank screen, audio comes in, no picture, cant get menu.
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
There is no picture on screen i can turn the power on and off thats all i can do i cant change the channel go to menu or anything else
Is the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Oct 15, 2008 | Televison & Video
AUDIO NO PICTURE
No picture is your problem? No model number but a suggestion if a LCD set---in a very dark room look at the screen with a flashlight--see a faint image of any sort there?
Nov 07, 2012 | Televison & Video
No picture but all the menu screens come on and look normal sometimes the picture will come on for a short period of time. and then shut off
if the TV dose not detect a viable video signal it will mute the sound and blank the video there is a preset minimum level that enables the audio and video, insure that the video source is of good quality and the cable you are using is good, if it is than you may have a problem in the video processing circuits of your TV, the good menu screens indicate this may be the fault,,, Good luck
Apr 24, 2010 | Televison & Video
Screen is blank but still takes pictures fine
Try removing the battery or reseting the unit if there is a reset button. Otherwise it sounds like the screen died.
Dec 08, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Picture has gone blank
Press menue to see if the menue pops up (yanno for sleep timer and stuff). If not, you need to have it repaired or need a new tv. You could try unplugging it from power for a bit, might help.
If you can see the menues then and your using HDMI, switch to a regular cable line and see if it comes in. Or just tune to channel 4 or somthing and you should get snow. Could just be the HDMI cable.
But if you cant get ANYTHING not even the Ch3 or Volume to show up on the screen, its the screen, a fuse or somthing else
Oct 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
I have a mitsubishi projection tv model vs-55601. The tv comes on but there is a blank screen. The audio is there but no picture.
Does the menu come up if you press the menu button? If not then there is a few things that can cause this problem. most likely is a fluid leak, to check for fluids i would take the front off the bottom of the set and look in with a flashlight and see if you see any liquid on the boards or corrosion of any type. let me know what you find.
TIm Nolan
Sep 13, 2008 | Televison & Video
Display is blank
I can take perfect pictures indisde a building, but taking a picture outside, I can see the item but if I take the picture and looking at the picture the screen turns blank, seems to me that there is to much light exposure.
Aug 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Blank screen while taking pictures
Sure this is a clear case of faulty CCD sensor if you can play back captured images ok. Parts and labor will set you back by +- $ 200 if you have it done professionally.
Sep 14, 2007 | Nikon COOLPIX P4 Digital Camera
AOC Envision L32W461 32 in. LCD HDTV Logo
26 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
