FixYa.com
Tags:
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
Fax machine Panasonic KX-FHD331 usage in India (220...
By Ranny - usenet poster
I have a Panasonic Fax Machine model :KX-FHD331 bought in the USA
where it is 110 V.  How can I use it in India where the voltage is 220
Volts.
Help is appreciated.
Thanks
Sundar
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 04, 2005
Not Rated (0)
Peter1
Peter1 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I'm not familiar with this particular unit, but fax machines are cheap.  If
you are moving to India, I'd suggest not carting that thing all the way over
there.  If you're just visiting, it might still be easier to buy or rent one
overseas.  You will be totally set up for any differences in standards
(voltage or phone) which might try to bite you.
If this is a high-end unit, all bets 'could' be off...but I'd seriously
consider as to whether this is more trouble than it's worth.
jak
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
Thanks for all the help.  I did find a transformer for 220 to 110 V on
the web.
I have another question.
This is about the 60Hz frequency indicated on the back of the Fax
machine.
The 220v in India is at 50Hz frequency.  Now will that matter to the
fax machine or cause any problem as once the AC is converted to DC by
the fax machine, I was told the frequency is lost and it no longer
matters for the operation of the fax machine.
Any suggestions or views on this?
Thanks
-Sundar
Solution #3
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
On 12 Jul 2004 09:51:03 -0700, sun @megacorp.org (Sundar) put finger
to keyboard and composed:
If you are lucky and the SMPS uses two 200V filter caps on the primary
side, then all you will need is a new fuse. You will also need to cut
a wire or a trace.
See how this ATX PSU does it:
 http://www.pavouk.comp.cz/hw/en_atxps.html
- Franc Zabkar
Please remove one 's' from my address when replying by email.
Solution #4
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
You will need a line transformer to change the 220VAC down to 120VAC
for the US modle. The wattage rating of the transformer should be a
minumum of about 40% greater than what the fax machine requires.
For safety I use a transformer rated at about double the wattage. Just
make sure that you have no more than 120VAC going to the fax machine,
and it sould be safe.
Jerry G.
Solution #5
Not Rated (0)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
use a control transformer? 2:1 with proper VA handling.
Can you Help with these Fax Machines problems?
Fax Machines
printing out black sheet!
printing out black sheet! Answer This...
Fax Machines
need instructions for replacing...
need instructions for replacing... Answer This...
Panasonic KX-FHD331 Plain Paper Thermal...
IN MEMORY
how do i get a fax out of... Answer This...
change from letter to A4
This fax only works with letter... Answer This...
Panasonic Cable?
Dear jaylex Thanks for the... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
