Need front usb motherboard configuration - Computers & Internet
  • 40 Answers
You dont need to configure any usb ports if the usb ports are enabled in BIOS all the usb ports will be activated automatically(front and rear). If still you want to check, go to BIOS and check if they are enabled.
Posted on Oct 05, 2009
Front panel audio and front usb not working on my windows 7
Is it because you installed windows 7 or what. cause that problem may have been caused by drivers or the front panel cables were not installed correctly. and some motherboards require some juper to configured to enable sound output
Dec 05, 2013 | ASUS P5GC-MX/1333 Motherboard
My acer aspire 5733Z-4851 donot read usb
That could be a problem with the USB connection on your motherboard. This is not a big issue, if you can you just open up your CPU and locate the USB connection on the motherboard. It is not clear to me whether it is the USB ports from the front panel or it is the USB ports that are on-board (usually found at the back). If it is the USB ports from the back, the one built - in on the board, then the BIOS has to be configured again to enable Plug and Play attributes. If the ports are from front then you need to follow the cable that connects the usb port to the mother board. Disconnect and reconnect. Or check whether it is actually connected to the right port on the motherboard. Usually it is written on the motherboard.
Jun 11, 2012 | Acer Aspire 5733z-4851
How can i setteled the front panal usb pin connect on the usb panal on motherboard gigabyte845 gvm-rz
There are 2 USB Ports for the Front Panel USB ie F_USB1 / F_USB2 beside the "PWR_LED". You can use either F_USB ports. Just plug in the USB cable pin accordingly in the Configuration below. Be sure the the negative & positve pins are correctly plug in or it might caused damage to you Mainboard. (Pins 9 &10 not used). For further reference you can download the manual @ Link
Pin No.- Configuration
1-Power 2-Power
3-USBDx- 4-USBDy-
5-USBDx+ 6-USBDy+
7-GND 8-GND
9-No pin 10-NC
Hope it helps.
Aug 06, 2011 | Gigabyte 8IG1000MK Motherboard
GA-8S650GXM FOR USB FRONT AUDIO PANEL
You will need the motherboards manual to help you with connecting USB_1, USB_2 and F_PANEL audio to you're case. If you do not have you're manual for the GA-8S650GXM you can download it from Gigabyte; http://america.giga-byte.com/FileList/Manual/motherboard_manual_8s650gxm_series_e.pdf
You will also need Adobe reader installed to view the manual.
Gigabyte GA-8S650GXM main web site; http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1658
Turn to page 18. Number 17, F_USB1/F_USB2. Use the link provided below to help you connect you're front case USB wires to the motherboard; http://www.directron.com/installusb.html
Turn to page 24, for front audio connections. Keep in mind once you configure you're audio to function from you're cases front audio port you will not be able to use the rear audio port. Caution, most people find bumping any front case USB or audio cords break far too easely. To avoid breaking the front audio port, consider using a Y splitter for the rear audio port as shown in the next link; http://shopping.yahoo.com/p:StarTech.com%20MUY1MFF%20Audio%20Video%20Cable:1991733360;_ylt=Ah94ikZN9zDbTi2.arc45BkbFt0A
Hope you find this helpful.
Mike
Jan 22, 2010 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
How to configure the front panel
If you're talking software then you will need to download and/or install the Chipset drivers from your install disk or online in order to get that stuff working. If you're talking how to connect the wires into the motherboard. You have to take a look at the words on the little wires and match them with the pins on your motherboard...They are often just a USB connection. just look at the configuration of holes for the connection and match them to any open USB set of pins on the motherboard with the exact same configuration. Contact me for more info if this sounds confusing.
ASpecialty4You.com
Dec 21, 2009 | Intel Desktop Board D850MD Motherboard
Gateway 506GR motherboard configuration
Item Description Item Description A Rear Panel I/O Ports M Front Chassis Fan Connector B Auxiliary 12-V ATX Connector N Serial ATA Interfaces C CPU Socket O Front Panel Header D CPU Fan Header P Front USB Connector E Memory Slots Q Front USB Connector F Standby Power Indicator LED R Front Panel IEEE-1394a Connectors G Floppy Disk Drive Connector S Speaker H ATX Power Connector T PCI Express x1 Connector I Parallel ATA IDE Interface U Front Panel Audio Connector J Battery V PCI Slots K Intrusion Switch Header W Rear Chassis Fan Connector L BIOS Configuration Jumper
Aug 21, 2009 | Gateway 506GR PC Desktop
I need a usb 2.0 driver for my biostar U8668 mother board
when u power up the computer press "del" or F2 kewy to tenter in bios then go to usb configuration then set high spped in usb 2.0
May 06, 2009 | Biostar U8668 Motherboard
Computers & Internet Logo
688 people viewed this question
David Payne
David Payne
