Question about Epson Stylus CX4800 All-In-One InkJet Printer
My printer will not print from my computer. The
My printer will not print from my computer. The on light is on, the ink and error lights are off and the sample sheet printed.
  • 3 Answers
SOURCE: Epson Stylus Photo 1290 Does not print.
Download Software maintenance and adjustment EPSON 12000 series Here
Posted on Dec 23, 2007
The Machine
  • 788 Answers
SOURCE: printer refuses to print anything
Rerun the CD that came with the printer.
Posted on Jan 11, 2008
SOURCE: R1800 printer problem
here has the all the figures and procedure to solve the problem
http://www.inkrepublic.com/KnowledgeBase/R1800PW.asp
Posted on Jul 15, 2008
yooperbud
  • 8637 Answers
SOURCE: communication error between Epson Printer and iMac
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
aicaxz
  • 511 Answers
SOURCE: c43 stylus does'nt print while red and green lights stay on
If the light are flashing, it mean waste ink full. You must clean waste ink pad, and reset the counter. You can use SSC, find at indoreset.blogspot.com. But,.. you said the light are on. try to resinstall driver. after printer recognised by comp, check status monitor. Green light on is power on, and red on mean chip error/ink out error/cartridge error.
Posted on May 30, 2009
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Where is the waste ink tank?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer won't print. Says to contact service
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ink well transformer full
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
C43 stylus does'nt print while red and green lights stay on
May 29, 2009 | Epson Stylus C43SX InkJet Printer
My printer is saying unable to print
Try one or more of these solutions:
  • Press the fontp.gif power button to make sure that the printer is on.
  • Turn off the printer and make sure that the power cord is securely plugged in.
  • Make sure that your outlet works and is not controlled by a wall switch or timer
Lights came on and then went out
The printer's voltage may not match the outlet rating. Turn off the printer and unplug it immediately. Then, check the printer labels.
If the voltage does not match, DO NOT PLUG YOUR PRINTER BACK IN. Contact your dealer.
Only the power light is on
  • Turn off the printer and computer. Make sure that the printer's interface cable is securely plugged in.
  • Make sure that there is no packing material in the printer.
  • Turn off the printer and the computer and disconnect the printer's interface cable. Then, print an operation check page. See Running a printer operation check.
If the check page prints correctly, make sure that the printer software and your application are installed correctly.
  • If you are trying to print a large image, your computer may not have enough memory to print. Try printing a smaller image.
  • Windows Me and 98 users can clear any stalled print jobs from the Spool Manager. For instructions, see Using EPSON Spool Manager.
  • If the printer sounds like it is trying to print, but is unable to, run the Head Cleaning utility.
Paper out light is flashing or on Check EPSON Status Monitor 3 (for Windows) or EPSON StatusMonitor (for Macintosh) to find the cause of the error, then try one or more of these solutions:
  • If the fontm1.gif paper out light is on and there is no paper in the printer, load paper into the sheet feeder.
  • If the fonth.gif ink out light is flashing, a low supply of ink is indicated. Obtain a replacement cartridge of the appropriate type. To determine which cartridge requires replacement, see Replacing an Empty Ink Cartridge.
  • If the fonth.gif ink out light is on and the ink cartridge is empty, replace the appropriate ink cartridge. To determine which ink cartridge is empty, see Replacing an Empty Ink Cartridge.
Error light is on and power light is flashing
Follow the steps below.
r_1.gif Press the fontm1.gif paper button, then remove any paper from the printer. r_2.gif Turn the printer off. Check for and remove any foreign objects or pieces of paper from inside the printer. Also, make sure that there is sufficient space around the vent on the back of the printer to allow proper ventilation. Remove any objects blocking the vent. Then, turn the printer back on
May 27, 2009 | Brother MFC-210C All-In-One Printer
Printer flashes code 5 .black ink light flashes & error light on.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Apr 27, 2009 | Office Equipment & Supplies
Epson Stylus CX4800 All-In-One InkJet Printer Logo
15 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
