Question about Garden
Mower stops when you engage blades and engine seems to back fire before stopping.
  • 148 Answers
Proabale suspect is the seat switch.
See Solution #2 HERE for testing procedure.
Hope this helps.
Posted on Oct 04, 2009
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
What makes the blades on a riding mower stop turning once the mower belt is disengaged?
The brake mechanism works when tension is released from the idler / cable. The brake is spring loaded to contact the spindle this stops the blades from spinning. I have attached a drawing showing the brake arm and where it can be found on the deck.
afzvk1vyaxgoaaaaaelftksuqmcc
Apr 15, 2017 | Poulan Garden
Safety switch located
Micro switches will just stop the engine if the blades are engaged and the operator leaves the seat, or will stop the engine cranking if the blades are engaged, it will not stop the blades from engaging.
Sep 06, 2012 | Murray Garden
I have a LT2000 21 HP lawn mower. The mower is brand new, just put gas in it today. I can't get the mower blades to engage without shutting the mower off. I have tried it in neutral, forward, sitting...
Hi, Have you tried to turn the blades by hand ( WITH THE MOTOR OFF ) I suspect there may be some transit packing that you may have missed. The blades should turn freely with the motor off and the blade engaged. There is a blade brake which stops the blades turning when the drive is disengaged which might need adjusting .
Hope this helps.
Dec 30, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
When deck is lowered blades do not engage
Is the belt in place that drives the blades?
Is the belt at the correct tension?
With the mower engine off.....try to turn each pulley the belt drives and on the mower deck with the mower in up position and or down....do they turn a little......this is to check for a seized bearing on one of the pulleys also look under the deck for something stuck........ jamming a blade.
Also check for the mower belt safety system (which stops the blades quickly when disengaging them) that may be stuck in stop mode.
With the mower engine running.....have some one engage the blades while you look under at the belt system....is the engine driving the belt.....is the belt driving the blades.
DO NOT TOUCH ANYTHING......MOVING OR STOPPED while the engine is trying to drive the blades.
Sep 06, 2009 | Mtd Garden
Mower blades engages but when I stop to empty grass they will not
yes it is there is one under the seat & under the dash & there is also one connected to the clutch/ brake peddle which is more than likely the one giving you problems is the clutch/brake peddle switch
Jun 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
