Question about Microwave Ovens
It just went dead after starting it. There is no
It just went dead after starting it. There is no power.
  • Microwave Ovens Master
  • 8,404 Answers
Remove the cover, find the fuse on the floor of the device near where the cord enters, check it - unplugged, OF COURSE. Do not touch the silver can - LETHAL! Use a contunity checker to check the fuse. Find a replacement at the hardware store or at an appliance parts supply. Take the fuse with you.
I hope this helps you.
a
Posted on Oct 04, 2009
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1430 Spacemaker is dead. Completely.
See my microwave oven safety file here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. How to test a high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. My door switch help file.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
If the fuse is easy to twist with your fingertips while it's in the holder, it's too loose.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 29, 2017 | GE JVM1430 Microwave Oven
Went to use microwave and it just went dead. Household power is fine and breakers are good. Replaced main fuse behind switch panel and got power back for clock etc.. When I went to run it again, it went...
short circuit in high tension power supply
DUE TO THE VERY HIGH AND DANGEROUS VOLTAGE 4000( V) IT IS NOT WISE TO FIX IT YOUR SELF UNLESS YOU KNOW WHAT YOU ARE DOING
Apr 26, 2010 | Maytag MMV5100A Microwave Oven
Microwave completely dead
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 04, 2007 | Maytag MMV5165 Stainless Steel 1000 Watts...
Advantium oven has no power
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 18, 2007 | GE Advantium SCA2000B Microwave Oven
Samsung microwave
Nov 07, 2007 | Microwave Ovens
Frigidaire Microwave
Dead? You mean no power, no lights, no beeps, nothing?
It's most likely a blown thermostat / thermal cutout on the magentron, based on your info.
But if you can post the model number I may be able to steer you better.
More generic info:
Oct 28, 2007 | Microwave Ovens
Kenmore elite microwave oven
thermostat to open.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
of the oven.
Oct 23, 2007 | Kenmore 63792 Microwave Oven
Panasonic microwave s254bf stopped working
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 21, 2007 | Panasonic NN-S254BF Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
