Question about Whirlpool Dryers
Drum won't turn - Whirlpool Dryers
  • Whirlpool Master
  • 7,482 Answers
Your problem could be a broken belt or a belt that has come off the motor or idler arm pulley.
Try this first:
Unplug the dryer, then reach inside and rotate the drum 1/4-1/2 turn.
Plug the dryer back in and push the start button. Sometimes this helps because a motor will get a dead zone in it and this will move it from the dead zone.
If that does not work, If you have a front loading machine:
Remove the front of the machine, this will expose the drum and belt, remove the drum and belt and this will expose the drum rollers, motor, and idler arm with pulley.
While you have the drum out of the way, it is a good time to lube the drum rollers and check them for flat spots. Lube the drum rollers at the shaft with a good grade of machine oil such as 3 in One oil.
If the rollers have flat spots on the, then they will need to be replaced.
I hope this helps
Posted on Oct 04, 2009
Why is my clothes washer constantly unbalanced?
loose or broken drum support wheel. under the drum that turns is plastic or metal wheels the drum sits on. when the wheel breaks or the metal bar that goes threw the wheel may loosen and work its way out the the drum won`t balance.
Apr 23, 2014 | Maytag Washing Machines
I have azanussi zwf1437w washing machine. The drum has become stuck and won't turn and can't be turned by hand. There are no socks etc stuck between the inner and outer drum that I can see.
Well, I hate to tell you, but the drum will have to be looked at and that means opening the machine up. It probably dislodged from its mounts from excess vibration caused by unbalanced loads in the drum.
Jan 15, 2013 | Zanussi Washing Machines
My candy dryer is heating but the drum won't turn what can i do
replace drive belt contact manufacturer for agents for parts
Oct 06, 2012 | Candy Dryers
Which way do turn the rear shoe and drum brake adjuster after putting new ones on
You turn the adjuster by hand or with pliers
Then slide the drum on & off a few times, until
the shoes are just touching & barely making a noise
Each side will turn opposite,you don't need to know the
direction,just adjust & try the drum on
You either have to have the drums machined or use a dremel
tool to grind off the step, or what I have told you & done for 48
years won't work
Oct 01, 2012 | Dodge Cars & Trucks
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
My dryer makes a buzzing noise when i try to turn it on, but it won't turn on at all. What could the issue be?
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch.
Sep 20, 2011 | Kenmore 62722 Electric Dryer
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
