Question about Garden
The engine dies once the brake is released
Riding Mower
The engine fires and turns over just fine. However, when you release the brake, the engine dies. Any suggestions?
  • 148 Answers
Seat switch is defective, obstructed or otherwise inoperable for one reason or another.
Check this:
Unplug the plastic connector from the seat switch.
If it is ONE SOLID connector, stop right there!
HOWEVER, look into the connector's terminals (not the seat switch's terminals, the tractor wiring harness terminals). If you see a small square divider between the terminals and that divider is a movable, inserted part (NOT an integral part of the connector's plastic body), take a small needle-nose plier and pull it straight out of the connector's body.
BEHIND that removable square plactic piece, locate and remove the tiny torsion spring from between the two terminals. Throw these two parts away and plug the connector back into the seat switch.
Hope this helps.
Posted on Oct 04, 2009
  • 389 Answers
Check the safety switch under the seat to see if it has come unplugged and also check it with an ohm meter to see if it is working properly
Mower cranks and runs fine but when I release brake pedal, it dies. I have check all safety switches and they all have continuity when they are suppose to
Sounds like your seat switch isn't working. Operator presence (seat switch activated) is required when the brake is released & pro is engaged or your engine will shut down.
Feb 14, 2016 | Garden
Why does mower die when brake released or mower engaged?
ck your occupant (seat) switch it might have gotten dislodged or unhooked when fueling it
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Why does engine die when brake released or mower engaged?
The first thing I would check is to make sure the drive belt is not binding somewhere.
I have a husqvarna riding mower and when i turn it on and release the brake the mower dies and when i put the blade on or give it gas it dies, but for the most part just releasing the brake after letting...
It sounds like the seat switch is not working. This switch must be made by a person sitting in the seat for the brake to be released or for the blades to be engaged. It is possible to start the mower with the switch open.
Gary
Jul 03, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine dies when brake is released
check if the switch for the blades or the brake is not releasing.
Jul 04, 2009 | Garden
Simplicity mower stalls when brake released
There is another safety switch connected to the parking/service brake. Check that one too. Sounds like its the one.
Jun 22, 2009 | Garden
Engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine dies off once brake/clutch is released
Your answer was perfect, when I located the saftey switch it was not working properly.
Thanks a million, Ron
Jan 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
