Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Interior bulb heating up
The internal bulb in the refrigerator overheated and melted the plastic enclosure holding it. The bulb is generating lot of heat spoiling the food contents below it. Solution appreciated.
Thanks in advance Chandra
  • 464 Answers
LG has had an issue with this and has re designed the lamp cover and the lamp holder itself. contact your nearest parts supplier with your model and re order this part and you will receive the new upgraded cover.
Posted on Oct 04, 2009
MY REFRIGERATOR LIGHT IS DOING THE SAME THING TOO LIGHT STAYS ON HOW DO YOU FIX IT
Posted on Jul 16, 2012
Changing to brighter headlight bulbs
You need to be aware that brighter bulbs have shorter life span and generate more heat. You need to watch the connections and be sure they don't melt. The plastic headlight enclosures don't offer good air ventilation.
Feb 08, 2017 | Cars & Trucks
Tip
Reduce risk of overheating and plastic melting if lights stay on
Even though I have found a statement (I think it was in the LG2.gif troubleshooting2.gif FAQS on line) that the lights in the newer LFX25960 french door/bottom freezer refrigerator will shut off after a period of time to prevent overheating and melting the plastic housing, I have heard of this problem enough times to worry about it. So I replaced the two 60 watt bulbs in my refrigerator with 25 watt appliance bulbs just in case. They provide more than enough light and do not get as hot when on. It took a while to find them. They are made by Philips2.gif and were at Home Depot but not always in stock.
on Sep 18, 2009 | LG LFX25960ST Stainless Steel French Door...
Headlights overheating and melting plugs
What type of bulbs are you using? If you are using quartz halogen bulbs and the housing was made for conventional lights, the housing and connections cannot take the extra heat that the bulbs make.
Mar 31, 2014 | Honda Motorcycles
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
The light has not been turning off which melted the plastic covering over the light bulbs and its not hanging by a wire and the light still on. the censers on the door do not turn it off anymore i...
Karri,
I experienced the same problem with my LG refrigerator (model LFC25760ST). Came home from a weekend trip only to find that the light bulb assembly had melted and dropped onto the top shelf. The interior of the refirgerator compartment was very warm (est. 70 to 80 degrees) and everything in it had spoiled. Fortunately, nothing worse had happened. (According to consumer information on the Internet this LG refrigerator is suspected - but not proven - to have been the cause of a couple of house fires.)
There was no recall, however, because the reports to the Consumer Products Safety Commission were for less than 5% of this model sold in the U.S. But if you contact LG customer service (1-800-243-0000) whether your unit is still under warranty or not they should send someone out to replace the lamp assembly at no charge to you - this one with a heat sensor that serves as a backup to turning the lights off once the doors are closed.
Newer LG refrigerators have LED lights instead of incandescent light bulbs so they don't produce enough heat to warm the interior of the fridge or melt the light housing.
To learn more about other folk's similar experiences with these LG refrigerators just do an Internet search using "LG and "LCF25760" and "melted plastic." (Note: Leave the other letters after the five numbers in the model number off - they only refer to the exterior finish [i.e., "ST" = stainless steel] and unnecessarily narrow the search so as to miss some links.
Good luck with LG customer service.
grm
Feb 15, 2011 | LG LRFD25850 French Door Refrigerator
Lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Dec 10, 2009 | LG LFX25960ST Stainless Steel French Door...
REFRIGERATOR LG LFC25760SW WILL NOT TURN LIGHT OFF. AREA WHERE BULB IS OVERHEATED, MELTING PLASTIC SURROUNDING IT. HOW CAN I SOLVE THIS PROBLEM? THE DOOR EVEN WHEN HELD OPEN AND THE BUTTONS THAT TURN THE...
Turn the unit off so the bulb can cool and just take it out. Sounds like there is a problem with the switch, as to the melted surround if it is part of the liner there aint nothing you can do, save patch it with fiberglass and resin.
Dec 01, 2009 | Dishwashers
Interior light remains on when the door is closed
i believe this refrig, is produced by the LG corp, ofr kenmore, they do have a repair for this issue, ( i just changed one last month), which inckluded replaing hte light housing(the new one has a high limit thermostat to cutt off lights in case of this prblem) as well as replacing hte main control board behind the unit.scream safety issue!!!!!
Feb 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
159 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
