Question about HP Pavilion zd8000 Notebook
Black and white wire from monitor to motherboard came lose on hp pavilion zd8000 laptop. motherboard is DANT2DMB6A0 REV A. it looks to be a ground and power, but can't seem to find where it plugs in. where does it go? wire isn't that long and I've looked where wires could reach, but still can't find it
    President:
  • 2,600 Answers
The black and white wire are the leads for the built in wireless card for internet and networking. Below is the manual for that particular laptop. The wireless card is accessed from a small panel on the bottom of the case. Usually held in place by two retaining screws. Lift off this cover, if you see a single card or slot with one bright retaining clip on either side, that is the wireless card(or slot if empty). The wires attach to the two small round sockets on the card. It is called a mini-pci card. Your manual is below, make sure to save a copy for yourself for future reference.....
http://h10032.www1.hp.com/ctg/Manual/c01383095.pdf
Posted on Oct 04, 2009
I have a hp pavilion dv7 and the power socket has come a lose i need to know which wire goes where.....
The DC Power Jack that the AC adapter (Charger) plugs into?
Look into the DC Power Jack with a magnifying glass and light you'll see it's a center pin surrounded by a barrel. Barrel has an inside and an outside.
1) Center pin. Gold and buried down in the plastic. Connected to WHITE wire at motherboard connector.
2) Inside barrel has 4 Brass fingers.
Orient the laptop so the LED is at 12 o'clock and you'll see fingers at 12, 3, 6 and 9 o'clock.
These fingers carry the + 19 volt power to computer.
The ones at 6 and 9 o'clock do, Noon and 3 are not connected.
+19 Volt power arrives at motherboard connector on RED wire.
3. Outside barrel has six brass fingers, at 2, 3, 4, 8, 9 and 10 o'clock.
2, 3, and 4 are not used,
2, 8, 9 and 10 are the power return (common, or ground) to computer.
It arrives at motherboard on BLACK wire.
4. LED is connected to YELLOW wire and controlled by computer.
Other side of LED is jumpered to a Black wire,(Ground), outside barrel 8, 9, and 10 o'clock.
From > analog posted in an HP Support Forum.
Nov 12, 2010 | HP Pavilion dv1000 Notebook
Vertical lines have appeared on my hp pavilion zd8000 can u tell me how to fix it please?
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mptherboard. If the problem appears on both screens, external and laptop, most probably the video card/motherboard is defective.
Have it checked/repaired by a professional.
Oct 08, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 got my first horizontal line.
A horizontal line on your LCD display is either caused by the video chip on your system board or the LCD screen itself. Either way it will not cause you to lose data on your hard drive. It is a video problem.
By connecting an external monitor from a desktop PC to the back or side of your notebook and switching to it by using your function keys (see manual), you can see if the problem is also on the monitor (meaning video chip problem) or stays only on the notebook LCD (LCD problem).
The video chip problem means you will need a system board. The LCD problem means you will need a new LCD panel. In rare cases, reseating of the ribbon cable on the back of the LCD panel will fix the red line.
Jun 18, 2009 | HP Pavilion zd8000 Notebook
I have laptop dell inspiron 9300 it 17 sreen , it has a white verticle white line about on the middle about inche 1 1/8 wide hohow to fix? thank you...very much
Unfortunately, there is no way to fix it.
This line called "Tab Separation" of LCD.
You'll need whole new LCD display.
Very very common problem.
Apr 29, 2009 | HP Pavilion zd8000 Notebook
Hp pavilion zd8000
You may be able to buy a replacement LCD from
www.laptoppartsonline.com
Feb 12, 2009 | HP Pavilion zd8000 Notebook
How do you turn on the dual monitor function HP Pavilion zd8000
Please check the Main monitor settings in Desktop - display settings. Also you can extend your desktop to the new screen.
Hope this change fixes your problem
Feb 07, 2009 | HP Pavilion zd8000 Notebook
Hp pavilion zd8000 inverter problem
you need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
Nov 17, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000
a power surge could have caused this problem, as you so rightly assumed. motherboards-cpus et,c. are prone to fail or malfunction. even with static electricity.
it could also be a sign that, the tft ( screen ) has faults or the cfl (tube) or inverter have suffered damage.
Mike @ compurepair.
Jun 10, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
648 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
