Question about JVC Audio Players & Recorders
Jvc pc-xt5 why my machine (Twin-cd portable system ) fails to read CD disc? Thank you so much. Mark
Benimur
  • 6966 Answers
SOURCE: CD Player problem
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded;
5. relube, clean as necessary
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 11, 2008
jerryg50
  • 1689 Answers
SOURCE: cd dvd wont play
Many of the older DVD and CD players will not play disks recorded on a computer. This has to do mainly with the laser optical response.
There were several manufactures that manufactured their laser unit with a built in filter that would not allow their player to read non pressed CD disks (disks burned with a home computer).
When buring DVD's or CD's, use the slowest possible speed for the burn to have the highest readablity and least data errors possible for the medium.
Jerry G.
Posted on Apr 19, 2008
  • 319 Answers
SOURCE: cd player will not read disc
Unit probably has defective disk motor or function sensor
Posted on May 08, 2008
SOURCE: c-314 stanton cd player, reads no disc, but disc is in cd player
as with my other posting - all i could do was mail it to be fixed. then it stopped working again so perhaps its time to go elsewhere.
Posted on Oct 13, 2008
  • 4 Answers
SOURCE: CD ROM ONLY READS CERTAIN DISCS
uninstall the drivers on cd rom.then restart the pc the pc will reinstall them
Posted on Jan 11, 2009
Broken Connective Cable for iPod JVC RDHA3B
Apple shop or where they sell that device or ebay, amazon etc. make sure you have the right model numbers etc
Feb 01, 2014 | JVC RDHA3B CD Portable Boomblaster for...
Cd inserted in cd player no disc
The problem is in the laser pickup assembly, overtime the laser becomes weak until it will no longer read the disc, it is far cheaper to replace the stereo than have the old unit repaired.
May 01, 2012 | JVC MX-GT80 Shelf System
JVC CD Changer says NO Disc
Make sure disc is clean and not scratched , if thats fine run a disk cleaner through it as dust could be on the lens , failing to read still is down to the laser failing.
Nov 16, 2011 | Car Audio & Video
I've got a JVC FS-G5 5 disc system. With multiple disc in the unit, it tries to read the CD, yet can't seem to find anything. It gives a "no disc" readout.
Is the cd's scratched at all? If cd's are fine? Clean the lazer eye with cotton swab and alcohol. please make sure the unit is unplugged.
Dec 26, 2010 | JVC FS-G5 CD Shelf System
Have a jvc MX-J500. (purchased as a previously owned unit) When a cd is inserted in any of the three trays it just says "no Disc". Radio works as well as the cassette player. System was dusty but appeared...
You could try a CD lens cleaning disc which will clean any dust off the laser lens. But it is possible the laser power can be low if it is an old player. this will stop the discs being read fence the fault No CD as it cant see the disc. This will mean either a new laser assembly or complete CD deck. Try the cleaning disc first and if that does not work take it to a service centre or just use it as a radio cassette in the garage.
Jul 21, 2010 | JVC MX-J700 3-Disc, Triple-Tray CD Changer...
Jvc ch-x350 12 disc cd changer. Loads cd but will not play it. reads: no disc and moves to the next cd and repeats. ??
If you are inserting non original cds, cds you make from your pc or cd copies sometimes they dont read, another reason is to make sure that you are inserting the disk with the correct side up, it will show you in the cd changer magazine slots. If none of this solves your problem then you have a defective cd mechanism and you need to replace or repair the changer. Very common problem with JVC Cd Changers, I used to replace them all the time and they tend to skip alot as well, get yourself a Pioneer if money is ok if not then follow my steps.
Good luck and dont forget to rate and vote for me if I helped you.
Thanks.
Jun 13, 2010 | JVC CH-X350 12-Disc CD Changer
Blu-ray dvd disc error on jvc th-g41. Will not play.
if your blu-ray is updateable then get update also try other disks
Apr 25, 2010 | JVC Th-g41 Theater System
My machine does not ready the Cd that i put in
1st - ensure your disc is of a compatable format with your Karaoke unit.
2nd - check the disc for dirty or scratched surface. Rectify disc surface as neccessary.
3rd - Have the Optical Lens (sometimes called the optical laser) cleaned
4th - depending on unit's age, the optical lens may be losing its ability to read different wavelengths, hence might read one type of disc, but not another.
Cheers,
"If this has helped you in any way, please rate this solution" :-)
Jan 27, 2010 | GPX Karaoke Party Machine CD+G Portable...
121 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
