Question about SoftMath Algebrator - Algebra Homework Solver (689076614429)
How do i show mapping diagram for algebra for these examples
How do i work out mapping diagram for algebra
    Champion:
  • 249 Answers
If you x and y concepts in problem then try to form one equation such as in linear or quadratic or your choice and make sure of x and y concepts in algrebra as x and y co -ordinate directions in graph
Posted on Dec 18, 2009
What does polynomial function mean?
Let us backtrack so as to better jump.
An algebraic expression may contain one or several algebraic terms, separated by a plus sign or a or a minus and a sign.
Each algebraic term is the product of a constant coefficient and a power of some variable, or the powers of several variables.
Example of an algebraic term 3(x^2)(y^6)....
If the exponents of the various powers are positive integers, the term is called a monomial. In short no square roots, or fractionary powers of the variables appear in monomials. Thus 2/x, 3SQRT(x), or 1/x^5 are not monomials.
Finally, a polynomial is an algebraic expression made up of one or more monomials.
Example P(X)=(1/3)X^7-(SQRT(5)*X^4+ 16X-25 is a polynomial of degree 7 in the indeterminate/variable X
Q(X,Y)= 3(X^3)*Y^2 + 4X-5Y+10 is a polynomial of degree 5 in the variables X and Y.
Oct 01, 2014 | Office Equipment & Supplies
Need a wiring diagram for map sensor in 2006 Jeep Liberty 4x4 3.7L
Go to autozone and ask for the wiring diagram. They will print one for you for free. If you dont have an autozone near you try another parts store. If you purchase a haines of chiltons manual ($25 in a retail store or $18 on amazon), it will have a detailed wiring diagram of the MAP sensor.
Good Luck!
Jul 13, 2014 | 2002 Jeep Liberty
2006 chrysler pacifica diagram of map sensor
on all cars, (in general,) the map can be only for EGR
or for FUELING. (the latter is called the SPEED Density System)
is this a USA car, and not Canada. (i dont do the market thing that is your job to tell me,or open hood and show me...)
MAP the out side diagram or the inside,
it is just an barometic sensor. some cars have 3 of them.
one for altitude , that you have yet to discover.
my guess ? i can t there are 3 engines. 3.5/3.8/4.0 liter
ill take a wild guess and land on 3.5L
the online fSM shows 21 diffr. (ign/fuel) systems.
the first 3.5l does use a 3 pin map and is the SDS, (map controls the AFR, there is no MAF air meter on car)
pin 1 is map signal out
pin 2 ECU quite ground.
pin 2 is 5vdc , refer. supply from ECU, also used for EGR feed back power at the EGR solenoid.
is that what you need?
the output is 0v-4v or tad more
and is an non linear function, that looks like the below.
your FSM will have batter facts.
this MAP is absolute type, that is it reads max.
under the full pressure of the atmosphere at sea level
or about 14.7 PSI.
here is a rev, engineered map as a guide, diff, car.
but works just the same way
http://www.fixkick.com/sensors/my-map.html
Oct 10, 2013 | Cars & Trucks
I need to know where vacuum lines hook up to the engine on a VN V8 ( injected). For example MAP sensor, Charcoal canister, Fuel pressure reg and dizzy advance?
I am sorry we do not have these diagrams. There was a sticker under the hood that showed this information, it is required by law and is commonly called the emission system sticker.
Nov 05, 2012 | Cars & Trucks
How can i draw a schematic diagram of the real number system?
You are talking about a real number diagram as if it were the schematics of an electronic gadget. there is not much to it. Just a few circles or enclosures embedded into one another. In any case here is an example of what you might want. Add any number you might think of in the correct region.
May 30, 2012 | Bagatrix College Algebra Solved Full...
What is the solution for (2,-5) (-3,4) in slope intercept form ?
there is an example worked out at the following link
http://www.algebra.com/algebra/homework/Graphs/Graphs.faq.question.134699.html
May 15, 2012 | Android Apps
Definition of special product in algebra types and example of special product in algebra
Product means the result you get after multiplying.
In Algebra xy means x multiplied by y
Likewise when you see (a+b)(a-b) it means (a+b) multiplied by (a-b), which we will be using a lot here!
Special Binomial Products So when you multiply binomials you get ... Binomial Products
And we are going to look at three special cases of multiplying binomials ... so they are Special Binomial Products.
1. Multiplying a Binomial by Itself What happens when you square a binomial (in other words, multiply it by itself) .. ?
(a+b)2 = (a+b)(a+b) = ... ?
The result:
(a+b)2 = a2 + 2ab + b2
You can easily see why it works, in this diagram:
2. Subtract Times Subtract And what happens if you square a binomial with a minus inside?
(a-b)2 = (a-b)(a-b) = ... ?
The result:
(a-b)2 = a2 - 2ab + b2
3. Add Times Subtract And then there is one more special case... what if you multiply (a+b) by (a-b) ?
(a+b)(a-b) = ... ?
The result:
(a+b)(a-b) = a2 - b2
That was interesting! It ended up very simple.
And it is called the "difference of two squares" (the two squares are a2 and b2).
This illustration may help you see why it works:
apb-amb-why.gif a2 - b2 is equal to (a+b)(a-b) Note: it does not matter if (a-b) comes first:
(a-b)(a+b) = a2 - b2
The Three Cases Here are the three results we just got:
(a+b)2 = a2 + 2ab + b2 } (the "perfect square trinomials") (a-b)2 = a2 - 2ab + b2 (a+b)(a-b) = a2 - b2 (the "difference of squares") Remember those patterns, they will save you time and help you solve many algebra puzzles.
Using Them So far we have just used "a" and "b", but they could be anything.
Example: (y+1)2
We can use the (a+b)2 case where "a" is y, and "b" is 1:
(y+1)2 = (y)2 + 2(y)(1) + (1)2 = y2 + 2y + 1
Example: (3x-4)2
We can use the (a-b)2 case where "a" is 3x, and "b" is 4:
(3x-4)2 = (3x)2 - 2(3x)(4) + (4)2 = 9x2 - 24x + 16
Example: (4y+2)(4y-2)
We know that the result will be the difference of two squares, because:
so:
(4y+2)(4y-2) = (4y)2 - (2)2 = 16y2 - 4
Sometimes you can recognize the pattern of the answer:
Example: can you work out which binomials to multiply to get 4x2 - 9
Hmmm... is that the difference of two squares?
Yes! 4x2 is (2x)2, and 9 is (3)2, so we have:
4x2 - 9 = (2x)2 - (3)2
And that can be produced by the difference of squares formula:
Like this ("a" is 2x, and "b" is 3):
(2x+3)(2x-3) = (2x)2 - (3)2 = 4x2 - 9
So the answer is that you can multiply (2x+3) and (2x-3) to get 4x2 - 9
Jul 26, 2011 | Computers & Internet
How to solve algebraic fractions?
http://www.revisionworld.co.uk/gcse-revision/maths/number-and-algebra/algebra/algebraic-fractions
this link shows the formula and how to solve algebraic fractions. . .
thanks and have a nice day. . . .
May 10, 2011 | Office Equipment & Supplies
How to put in a = sign in my problem
The = sign will not always show on the calculator it will depend on what type of problem you are solving.
For numeric problems an = sign will come after the problem is input and the answer will display.
For algebraic or function problems you can input an = sign in the middle of the problem. An example
may be that you input a function. You would input a function by typing in f(x) = 5x + 2 (for example).
Apr 03, 2011 | Casio fx-300ES Calculator
Math algebra 1
hi,
answer is 6.
example..
if the question is 6.57 it can be rounded to 7.
since the digit in the tenth place is less then 5 it to the previous value.
thank you.
Jun 21, 2008 | SoftMath Algebrator - Algebra Homework...
Computers & Internet Logo
1,184 people viewed this question
Top SoftMath Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Piyal Perera
Piyal Perera
Are you a SoftMath Computer and Internet Expert? Answer questions, earn points and help others
