Question about Intel Motherboard
Ax4spe max trouble
Blinking white line is all i get.......says i might have problem with pci card when i dont even have any installed
Kind of MoBo please.
If all you get is "blinking white line" where does it say the pci card may be a problem?
Some built in hadrware is sometimes listed as a pci device, so it maybe better to check your MoBo drivers which can be downloaded from the vendors site.
You typed this problem, which means you can somehow download the drivers and put them in some kind of media to install them.
More info about your system is needed.
Posted on Feb 02, 2008
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
I have an Advent DT2204 desktop pc itried to fit a wifi pci card and it would not fit, will a pci e card fit ? The slots would not line up with the pci card.
Save yourself a headache and get one like the one in the link below. It's super small, very fast, extremely cheap $10, Installs right in a usb port, and if your operating system is windows XP or later it should even auto install the drivers for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16833315091
Jun 27, 2012 | Computers & Internet
I got a used pc and i went to start it and it didnt boot up but the internal speaker said there was a problem with the pci card, i have installed a different video card, wireless card and a sound card, i...
I am not sure there is a question here, if there is what is it? One note Fixya has no drivers or software, it is copyrighted and we are not free to use it without a license from the manufacturer of each and every line of code.
Jan 18, 2012 | AOpen AK77-600 Max Motherboard
What type of video card can I use on this motherboard? D945GZIS AGP? PCI? PCI EXPRESS?
Your MoBo has (1) of each PCI Express x1 & and PCI Express x16 slots, and (2) standard PCI slots. There are NO AGP bus slots on this board. You'd want to use buy a PCI Express x16 video card instead of a PCI video card due to the better performance offered by the PCI Express cards.
The full details of your motherboard are below:
Product Description The Intel Desktop Board D946GZIS delivers an integrated graphics solution in the Essential Series by combining exceptional value with quality and reliability and supports Intel Core2 Duo, Intel Pentium D, Intel Pentium 4, and Intel Celeron D processors with 1066/800/533 MHz system bus in the LGA775 package. This board features a PCI Express x16 connector, integrated 10/100 LAN, dual-channel DDR2 memory, Intel High Definition Audio (Intel HD Audio) and up to eight USB 2.0 ports.
Processor Model: D946GZIS Chipset Type: Intel 946GZ Express Processor Socket: LGA775 Socket Installed Qty (Max Supported): 0 ( 1 ) BIOS Type: Intel Storage Controler: ATA-100
Memory RAM Installed ( Max ): 0 MB / 4 GB (max) Supported RAM Speed: PC2-4300, PC2-5300 RAM Features: Unbuffered, dual channel memory architecture
Audio Audio Output: Sound card Sound Output Mode: 5.1 channel surround Compliant Standards: High Definition Audio
Expansion / Connectivity Expansion Slot(s): 1 PCI Express x1, 1 PCI Express x16, 1 processor - LGA775 Socket, 2 PCI, 2 memory ( 1.8 V ) - DIMM 240-pin Interfaces: 4 x Hi-Speed USB - 4 pin USB Type A, 1 x serial - RS-232 - 9 pin D-Sub (DB-9), 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25), 1 x display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45, 1 x audio - line-in - mini-phone stereo 3.5 mm, 1 x audio - line-out - mini-phone stereo 3.5 mm, 1 x microphone - input - mini-phone 3.5 mm, 1 x storage - floppy interface - 34 pin IDC, 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style), 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
Nov 03, 2010 | Intel D915GAV Motherboard
What type of graphics card would I need to upgrade
Open the case.
Is there an add-on video-card, or is the video "integrated" onto the motherboard?
If not, then look at the "empty" slots for add-on cards.
The WHITE coloured slots will take a PCI (not PCI-Express) video-card.
If there is a BROWN slot that does *NOT* line-up with the ends of the WHITE slots, the slot will take an AGP video-card.
If there a DARK-coloured slot that *ALMOST* lines-up with the end of the WHITE slots, the slot will take a PCI-express video-card.
Mar 26, 2010 | Dell Dimension 1100 PC Desktop
I have installed 3ds max ,the problem is i am not
it is a very heavy software due to which it slow down the pc.if you want it expand the ram memory to 2 gb.if any problem please call me on 9920207375
Sep 20, 2009 | Autodesk 3dStudio Max 9 for PC
Install
This dependson your motherboard mate... the PCI port is the white one on ypur motherboard so all you need to do is line up the pins n just seat the card like a plug.. you might have to undo a backplate where the connector will go at the back of the tower.. screw the video card in n voila
Feb 12, 2009 | SPARKLE Computer Sparkle GeForce 8500 GT /...
Sign of the Dead Videocard?
There is a problem in your display card. please replace it. Insert an graphic card into PCI slot of motherboard. The PCI slot will be in white color. Thank you..
Sep 10, 2008 | HP Pavilion zd8000 Notebook
Aopen Ax4sPE-n
AOpen's website search will get you to the right motherboard with downloads for manual. First box = motherboads, Second box = Ax4spe-n will get you to what you need. There is nothing later then 2003 on any of the downloads
Please compensate my efforts as a show of good faith as most people do not know how much effort has to go into troubleshooting their problems and most would rather forget rather to continue helping the technician develop the necessary information to solve the their problems. This may sound like begging but it's not, it's a matter of fact.
Aug 28, 2008 | AOpen AX4SPE Max (91.8AT10.501)...
Intel Motherboard Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
