I need to extract a dime that found its way into the outlet pump on the right side rear of my Oasis model number 110.27072604. There are no manuals for this unit online. Are there any how to guides that can walk me through breaking down the pump so I can extract the dime that rattles around during every rinse cycle?
  • 1 more comment
  • mmfxtt Oct 06, 2009
    The first reply gave me a general idea, but the schematic was sub par. I need a detailed and sharper image of the pump area. I am really angry that Sears in their infinite wisdom have not printed a repair guide for this model HE washer. Please help!
    Mmfxtt
    Sorry, no glass door on this model. Are there no schematics or diagrams of this particular model? How did they assemble it at the plant?
    Intuition?
    mmfxtt
  • mmfxtt Oct 07, 2009
    On the surface, this solution may prove to be viable, however, until the manual arrives we will reserve judgement until that time. But thanks for the effort, your time was appreciated.
    President:
  • 1,734 Answers
Here is the repair manual for your 110.27072604
I researched this for you, please leave a good rating!
Posted on Oct 06, 2009
    President:
  • 1,653 Answers
You need to unplug the machine from the mains and turn off the water supply. Then remove the lower cover, looking at it from the front where the glass door is, so you can see the water pump. On the water pump there is a round cover, turn it counter clockwise to get it loose, then the the filter will come out. You may find some interesting things in there! Small coins, gum, paper, clipsm nails and jewellery are normal. Clean it thoroughly and screw it back on. Make sure the machine is powered off at the mains for 30 minutes in total to reset the computer and clear the fault display. Reconnect the mains power and turn the water supply back on. The machine should now operate correctly
  • 1 more comment
  • Karl Wright
    Karl Wright Oct 06, 2009
    If the pump is at the rear of the machine then you may also need to remove the rear panel to access it. Also if you need to remove the pump entirely then disconnect the water hoses for in and oy and then unscrew it from the chassis.
  • Karl Wright
    WATER PUMP
    Water Pump
    #1 -- washer pump, complete (2 port pump # 350365, 3 port pump # 285317, 4 port pump # 350367)
    #2 -- Screw, 10-12 x 5/8
    #3 -- Sleeve
    #4 -- Spring, toggle
    #5 -- Pulley
    #6 -- Lever, valve
    #7 -- Rod, connecting
    #8 -- Bearing block assembly
    #9 -- Wick, oil
    #10 -- Screw, pump to gearcase
    Water Pump
    #1 -- Whirlpool washer pump, complete (2 port pump # 350365, 3 port pump # 285317, 4 port pump # 350367)
    #3 -- Sleeve
    #5 -- Pulley
    #6 -- Lever, valve
    #9 -- Wick, oil
    #10
  • Karl Wright
    If you cant see the picture then go to the following site that shows a Whirlpool equivalent - Kenmore is part of the same family.
    http://www.appliancepartspros.com/bd_whi...
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please follow this procedure to check and remove the drain pump for your washer, also check the schematics--
You will need to drain all the water out of yourwasher by hand. Then tip the washer backwards and remove the lower bottompanel. There are 3 or 4 screws in the front holding the bottom panel on.Once the screws are removed then you can accesses the drain pump near themiddle right area. The drain pump is a black or grey plastic device about 6inches in diameter. There are 2 large hoses connected to the drain pump. Removethe hoses to see if you can see what is jamming the pump. If you find somethinginside then remove the jam and you should be good to go, otherwise you willhave to replace your drain pump motor as sometimes lint will get inside andwrap around the bearing and you can't access it to take it out.
    Click on the image to Zoom In.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Posted on Oct 04, 2009
    My machine is a kenmore elite oasis mod 27042603 I need a pump for the washer. It makes a grinding noise when it starts to drain. I took it apart and did not see anything in it that might be obstructing...
    You can order parts from any of the following websites:
    searspartsdirect.com
    pcappliancerepair.com
    repairclinic.com
    Make sure you use a complete MODEL NUMBER to ensure you find the correct parts listing. The first three sites listed also include exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The Oasis has two pumps. One is a drain pump and one is a recirc pump. The pump you are referring to, I believe, is the drain pump. Prices vary between sites, so shop and compare.
    If you do not find your model number listed at all the sites I have provided, use the part number from the Sears site for your search criteria. In some cases, the model number may not be listed, but the part numbers will.
    If you need guidance on how to replace the pump, the following link explains how:
    http://www.fixya.com/support/r4155097-checking_drain_pump_whirlpool_cabrio
    The Cabrio is the Whirlpool version of your washer. Both models are manufactured by Whirlpool and the washers are configured the same, so these instructions should apply. If you have any questions, please post back and let me know. I hope you find this information helpful.
    Dec 23, 2010 | Kenmore Oasis 27042 Top Load Washer
    A pulled fuse panel for a 2003 Jeep Liberty, there are 39 fuses inside a vehicle. I need to know what these fuses are and what they go to.
    The fuse box diagram is a sticker placed on the inside of the fuse box cover. This cover is located on the left end of the instrument panel (driver side). The sticker just uses numbers to indicate the fuses. I will match the fuse number with its purpose:
    1. Power Outlet, Front
    2. Rear Fog Lights
    3. Horns
    4. Headlight, Low Beam, Right
    5. Headlight, Low Beam, Left
    6. Body Control Module / Power Door Locks
    7. Spare
    8. Spare
    9. Right Park Light / Right Tail Light / Trailer Tow Lights / Cluster
    10. Spare
    11. Flasher
    12. Stop Lights
    13. Body Control Module / CMTC / Cluster
    14. Spare
    15. PDC Fuel Pump and Auto Shut Down Relays / SKIS
    16. Power Outlet Rear
    17. Rear Wiper
    18. Radio Choke
    Jun 19, 2010 | 2003 Jeep Liberty
    Washer will not drain
    Hello,the drain hose COULD be plugged.
    Mine had the PUMP INLET plugged with lint/dimes.
    That's right, three dimes and some lint kept the water from getting to the pump.
    For even an inexperienced handiman, the fix is easy.
    1) DISCONNECT THE POWER !!!
    2) Open access door in middle of back panel - 4 screws
    3) Disconnect pump inlet hose - pump is on the floor/left as you face the inside from the rear. Have lots of towels handy as water will run out of the tub. This is a simple hose clamp - you dont have to remove the clamp - only loosen enough to remove the hose.
    You can tell the inlet hose as it comes from the tub.
    The outlet hose exits the pump and exits the machine.
    4) stick your finger into the pump inlet and feel for any debris. I have found much lint and small coins. Somehow dimes get into the pump inlet and make perfect check valves preventing water from getting into the pump.
    Remove the debris.
    5) reconnect the pump inlet hose
    6) replace back access panel.
    7) plug back in and test.
    If it does not drain now, you may need a new pump.
    For even a handyman with four thumbs, this procedure should take less than 30 minutes !
    Thanks
    May 24, 2010 | Kenmore 45087 Front Load Washer
    I need to take case off oasis He washer. Need manual
    hi,
    the front of the machine can be accessed by removing the body of the machine. this can be done by putting a screw-driver just below the rim of the body at the top. most of the machines in this series do not have screws on them, but fo check if u have any in your model(you haven't mentioned the model number). then, you can lift off the body by taking it off to the right and left along the lip.
    cheers
    Jul 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    Hole in pump caused by coin -- causing flooding
    There is no screen! I bet it was a dime that was caught in the pump. It has happened to me several times to the point where we double check all pockets when loading washer. Coins larger than a dime stay in drum or in lower basket. Poor design! I now leave the back of washer loosened and have mastered pulling hose off the PLASTIC pump housing and reaching in to pull out the coin.
    Apr 06, 2009 | Kenmore Oasis HE 27062 Top Load Washer
    Washer making a weird noise
    I didn't get to answer this but It makes "cents" to me.
    Sep 09, 2008 | Kenmore Oasis HE 27062 Top Load Washer
    Not draining all the time
    I had this same problem with my washer a few years ago. I finally opened it up and found that there was a dime inside the pump blocking the outlet for the water. Sometimes the dime would not perfectly block the hole, so it would work fine, and then the next day it wouldn't work. No idea on how it got inside the pump, but I got it out finally. It could also be a problem with the timer......I would say you should at least call a service company and ask them first.
    Sep 04, 2008 | Kenmore Elite 45986 Front Load Washer
    forgot to include the most important step! We got the dimes out after wadding up a small piece of duct tape, sticky side out, and using locking forceps to grip the tape while fishing out the dimes from the drain pump.
    Sep 03, 2008 | Kenmore Oasis HE 27082 Top Load Washer
    Wheres the model number?
    ok the model number is on a silver plate inside the door or on one side of the machine. the outlet filter in on the pump you have to take the front bottom cover off and you will see the pump it is hooked to the drain hose screw off the filter that is on the pump it is a slot turn counter clock wise and then pull out and clean
    Dec 18, 2007 | Frigidaire ATF6000ES Front Load Washer
    Oasis washer
    remove the agitator, then remove the flat steel nut near the bottom. the tub should come right out. you'll need to get a new seal for the tub.
    Jun 07, 2007 | Kenmore Oasis HE 27062 Top Load Washer
    Washing Machines Logo
    43 people viewed this question
    Top Washing Machines Experts
