Question about Toshiba RD-XS32 DVD Recorder
Fault code ER 7071 on Toshiba HDD drive model
Fault code ER 7071
TENGO UN TOSHIBA DVD RECORDER Y EN LA PANTALLA TIENE UN ERROR ER7071, COMO PUEDO ARREGLARLO?
Posted on Jul 26, 2013
Where can I get the manuals (user, setup, maintenance) , drivers, etc for a Toshiba DP-2510 with ADF and Finisher?
Hi
You can pick up a list of fault codes and for a small sum a service manual (PDF version) from this site:
Error Codes Toshiba DP2510
A google search also gave this site:
Toshiba DP2510 Service manual Parts Repair manual download
which shows the manuals you can get from them. It seems to be a different part of the same website as the first link.
I also found this page at the "Manuals Club" which looks like you can get a range of manuals from them,
User Guide Instructions Book Operating Manual Service manual Workshop...
but the top search answers are interesting as none refer to a "Toshiba"!
Like you I have tried and bounced on the Toshiba website.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 04, 2014 | Toshiba Axiom 60GB HDD for Toshiba...
Toshiba Canvio 1 TB connection problem - physical layer issue may be on cable or on HDD mini-USB port itself
More than likely, this is some sort of fault in the logic of the external enclosure. The solid light indicates that the drive is powered and is awaiting access while the blinking light means that it is busy working. If you are unable to get the drive to do anything (whether reading data from the drive or storing data to the drive), then I would guess that it is time to see whether you still have warranty coverage on the drive and, if so, get it replaced under warranty.
In my experience, I have found that Toshiba drives are very unreliable and therefore would recommend that you replace it with a Seagate if this drive no longer has any warranty coverage. Of all the drive manufacturers, I have found Seagate drives to be the most stable and reliable. Others may recommend Western Digital but I replace failed Western Digital drives on a constant basis in my computer repair business each and every week while Seagates keep on going. I base my recommendation on being in business now for over 25 years.
Sep 10, 2014 | Toshiba Canvio Computers & Internet
Toshiba 1tb hdd external hard drive not reading
Try using HDD Regenerator to check and possibly to repair the disk. HDD Regenerator allows to repair bad sectors on damaged hard disk drives without losses of the existing data. http://ulozto.sk/xzjZ2Bd/hdd-regenerator-1-71-keygen-h33t-murtajiz-zip
Jan 11, 2013 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
ER code, flashing touch pad selections.
It is most likely a fault with the keypad mebrane on the dishwasher control panel. Need model number of dishwasher to make a more detailed conclusion.
Jan 04, 2013 | Frigidaire Dishwashers
Toshiba StorE ALU 3.5" external HDD stops out of the blue.
Toshiba could only replace my HD after destroying the data on it, So I just bought a separate empty HD casing instead and opened the Toshiba casing and took out the Western Digital Harddisk. The harddisk was perfectly working, It seems that the Toshiba controller in their casing got messed up. (Never a Toshiba for me, because by solving the problem myself in the appropriate manner I lost their useless warranty).
Oct 02, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
F103 ERROR CODE IN TOSHIBA E-STUDIO 282
F103 indicates HDD transfer time-out.
U can try format the HDD (08-690).
Then u perform the bad sector check (08-694). *take long time
If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
* replacement of HDD require firmware update
Jul 02, 2009 | Toshiba e-STUDIO 282 Black and White...
Code E602-0001
E602 error means that there is a Hard Disk Drive problem ( 2.5inches Toshiba HDD that you should order to Canon, only a few models of HDD works on this machine )
Regards, Mug.
Nov 17, 2008 | Canon PC-795 Copier
ER7071
es liegt bei diesem fehler an dem dvdlaufwerk
bei mir war es ein loses kabel und eine blokade im dvdlaufwerk
nachdem ich es gesäubert hatte und wieder zud´sammengebaut läuft dvd-recorder ohne probleme
Jul 26, 2008 | Toshiba RDXS54 DVD Recorder/HDD Recorder
F120 fault on Toshiba estudio 232
HOW TO RESET ERROR CODE F-120 IN TOSHIBA STUDIO 232
Jul 09, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba d-r2
If it's 7071, shut the unit off by holding the power button until the time is displayed (instead of the error code). Unplug the unit. When you open the case, you will see a white plastic piece at the front of the dvd drive near the silver plastic hinge on the face of the unit's dvd opening. The white plastic piece slips in the groove of the hinge to stop the units dvd door from being opened while the drive is engaged. Push the white plastic piece in toward the dvd drive; sometimes the mechanism gets sticky. Plug the unit back in and press the power button. This may solve the problem Hope this helps.
Aug 06, 2007 | Toshiba D-R2 DVD Recorder
Toshiba RD-XS32 DVD Recorder Logo
407 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
