Question about Panasonic Lumix DMC-FS3 Digital Camera
I dropped my camera and the lens is messed up what do i do to fix it?
My cam was dropped accidentally due to which the lens got stuck pretty badly, i had it repaired by a registered dealer/repair shop for casio cameras. the lens were working the way they should be when...
The fix is to contact the repair shop and explain that they may have "unstuck" the lens but they messed up the focussing. Let them fix it on their dime, not yours.
Jun 23, 2011 | Casio Exilim Zoom EX-Z9 Digital Camera
When camera is turned on the lens won't open, message comes up lens error will shut down automatically
Was the unit dropped or were any liquids messed onto the lens assembly previously ?
If dropped (particularly if the lens was open) the lens drive mechanism might well have suffered damage.
If liquids, particularly ones containing sugar, were accidently messed onto the lens assembly, then the sugar becomes sticky as the liquid dries, effectively glueing the mechanism in place.
Jun 11, 2011 | Canon Cameras
I Have A Cannon Camera. And It Wont Turn Back On!
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 17, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
My daughter dropped my camera it was in the case and now y camera is blinking f is my camera messed up or is it the lense?
Hi mom_0809, According to the manual page 132, it says F- - blinks means No lens attached, non-CPU lens attached. Solution is to attach the lens, select mode M. If the camera sustained a violent drop maybe the lens internals became damaged. Remove the lens then put it back on. Turn to page 129 for how to reset the camera. Does the F- - blink with another lens. If so then the camera should go to Nikon for a CLA
Jun 15, 2009 | Nikon D80 Digital Camera with 18-55mm Lens
Olympus Fe-310, lens is messed. Possible sand in it but not sure.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 14, 2009 | Olympus FE-310 Digital Camera
Zoom lens broken nikon coolpix L1
hi
the lens alignment is messed up you can try to push it while slightly turning it or slap/tap the sides of the lens to fix it...
Aug 11, 2008 | Nikon COOLPIX P4 Digital Camera
Kodak easyshare E45
the lens alignment of your camera is messed up it will take service repair to fix it, it would cost you the same for a new one...
however there is an alternative solution but this seems weird it up for you to try...
try to slap your camera several times on the side of the lens or try to intentionally drop it but not to hard, drop it on a carpet or somwhere thats not hard..
google this: error 45 on kodak easyshare LS753
then choose the 5th result youll find forum about this wierd solution...
Thanks! and good luck!
Aug 10, 2008 | Kodak EasyShare LS753 Digital Camera
Lens error 22
The camera can be fixed. The lens and any other parts will have to be replaced.
You should first get an estimate for service. It may be cheaper and better to replace the camera.
Jerry G.
Jul 30, 2008 | HP Photosmart M425 Digital Camera
It says lens error
its probably broken but the black slides that cover the lens if you play with it alot or push them in when the camera's turned off the lens mess up or if you've dropped the camera too much the lens break on the inside.
Jan 22, 2008 | Optimus DC-5347 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Panasonic Lumix DMC-FS3 Digital Camera Logo
51 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
