Question about Kenmore 24032\24036 Top Load Washer
The drum shakes out of control - Kenmore 24032\24036 Top Load Washer
  • 464 Answers
Lift the lid and look at the 4 corners of the tub and see if your machine has 4 round straps that secure the tub to the outer frame.
Posted on Oct 04, 2009
Kenmore 600 washer shakes when agitating and spinning. Drum seems loose. What to do?
Well, based on my experience, it seems to be an issue of suspension rods which supports drum or it can also be an issue of drum belt or bearings.
You can schedule a service by contacting Sears Home Services via chat. Please login to www.searshomeservices.com. They will help you to schedule a service.
Jul 29, 2016 | Kenmore Washing Machines
When the machine is on spin the machine shake so bad that it jumps
If the drum has an unbalanced load any machine will shake like crazy during high speed spin cycle - some even have a buzzer and shut down! Rearrange the clothing in the drum.
Oct 28, 2015 | Washing Machines
It shakes excessively on spin cycle, machine is level, it does it on every load, it is beginning to tear up door seal
It shakes when off balance. Your wash load may be balanced but the drum may not be. This could be down to the drum bearing or the "spider" that holds the drum in place. If one of the arms is broken it will spin off balance.
Oct 26, 2015 | Washing Machines
Why are the copies in an oce 7055 copier coming out very dark
The Electrostatics Control is not cleaning up excess toner from your printer drum probably a pro help is required try this - remove the toner and shake it laterally fix it back and check - also at the contrast setting and adjust if required
Jun 28, 2015 | Office Equipment & Supplies
Drum spining out of balance
Check inside to see if one of the drum springs has come off or broke.
Nov 04, 2012 | Maytag MAV7600 Top Load Washer
Drum shakes during spin cycle
I have a 7 year old duet washer. It started to shake during the spin cycle. It is level and the shocks and springs holding the drum are working. When the washer gets to the spin cycle, it is apparent that the drum is off center.
I tore the machine apart and found that there is a bracket at the back of the drum. This bracket sits in water so it was covered in slime. I found several large cracks in the bracket. Once these cracks occur, there is now way the drum can spin correctly. The bracket is welded to the back of the drum, so it has to be completely replaced.
What a poor design. I would guess that many, many other people will be seeing the same problem within a couple years. I was lucky in that I did not pay for a repairman to try to fix it.
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Washer Model FWT647GHSO
I had the same problem with my FWT647GHSO front loader shaking, the bearings in the outer rear drum were gone, I repair machinery for a living not appliances ( except my own ) and the job took me close to 4 hours to complete, it is working well now but I did notice some hairline cracking on the yoke that holds the inner basket so I guess it's time to start saving my pennies for a new one :( too bad the inner drum is ~$200.00 or I would endure the 4 hours labor again to replace that as well. Best of luck
Jun 23, 2008 | Washing Machines
Basket on washer shakes
Try lifting the inner drum to check if there is any movement between the inner and outer drums, also turn the drum and listen for any grinding or scraping sound from the rear of the drum. Its possible that your bearings have gone out & need to be replaced. The job is far from easy.
Jun 17, 2008 | Washing Machines
My Maytag top loading washing machine mdl#LA412 shakes violently on spin cycle with no clothes in it, a mechanic leveled the feet but it still vibrates bad. Any suggestions please!!
The ground under one of the feet may have collapsed.
The drum may be loose.
One of the springs that support the drum may have broken.
Check the machine by just trying to wobble it on it's feet, this way you can tell if it is firmly on the floor. check that the machine is level
Look down on the drum against the body and see if it is central to the frame and just get hold of the rim and try to give the drum a shake and see if it is loose, these machines always shake a bit because of the design, they are normally used in nursing homes etc in the uk
Feb 04, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
