Question about Dell (E210882) Motherboard
E210882 board - Dead video
The on board video is dead.
How can I trouble shout the problem?
How can I disable it and replace with an alternative board?
Thanks
Avi Manor
avimano@gmail.com
  • 2 more comments
  • Avi Manor Dec 23, 2007
    The onboard video is dead, so I can't access the BIOS setup.
  • Avi Manor Dec 29, 2007
    My problem is solved, and the computer works fine.
    I
    had to physically remove the alternative video board from the computer.
    Then the BIOS switched to the on board video adopter.
    I also had to download a suitable driver from Intel site.
  • Anonymous Mar 18, 2009
    Hey I have a Dell E210882 Motherboard, I recently tried to upgrade the RAM from 512MB to 1GB however after i switched the memory cards, my on-board graphics card stopped working. Now whenever i boot my monitor doesn't do anything. No blue screen no nothing.
    I tried switching back to the original memory sticks (512MB) and yet the problem persists.
  • JackDaniels3 Mar 18, 2009
    I tried switching back to the original memory sticks (512MB) and yet the problem persists. I powered down took everything apart and re-connected it.. still nothing
    Now whenever i boot; my monitor doesn't do anything. No blue screen no nothing. Essentially it seems the on-board graphics card isn't communicating the monitor.
    I use a Gateway EV700 Monitor.
    I don't have another graphics card.
  • 31 Answers
For the onboard graphics card to be disabled you have to restart your computer and click on the "delete" button as much as you can untill you can log on a blue screen "setup screen", or if you can read that the motherboard requires you to click on another button to enter setup "usually F2" the click on it untill you enter setup, then just move the keyboard direction arrows till you get to the choice "integerated periferals" from there you will be able to find another sub choice that tells you your graphics card type, then while on that choice press enter to open it's menu and choose "AGP" or you could also find a choice that says "on board graphics card" then you get to it and press enter and choose "disable" if you're having any trouble with what i just poster you can reach me on my msn or yahoo chat accounts "ahmedconta@yahoo/hotmail.com"
Posted on Dec 22, 2007
I can jump it but then it runs for a minute and then quits running
Hi, if the car dies after removing the jumper cables, the alternator is not working. Remove it and have it tested at your local parts chain. If you have any questions, please let me know, and thanks for using FixYa.
Feb 02, 2011 | 2001 Pontiac Montana
Tv doesn't come on. when tring to turn on you hear a buzz then it turns back off. Could it be the power supply board?
No,check for loose FBT-flyback tranformer connections a big black block of a plastic with a wire to a board section call highvoltage deflction board area.Useally the FBT is dead,require replacing and trouble shoot the deflection board area for other dead parts.Get quote prices from shops.Must hire a tv Tech. must do alot trouble shooting and replacing components.
Jan 01, 2011 | RCA P61940 61" Rear Projection Television
No display
You need to do some simple tests. First make sure the monitor is working - test it with another pc.
Start by disconnecting everything and try to boot at least in the BIOS; if it's the same then replace the power source and try again; if it's the same then install another video card in it and try again; if it's the same then replace the memory sticks and try again. Finally replace the processor and try one more time - if even now you can't get the video to show up then the motherboard is dead, replace it.
Nov 19, 2010 | Dell (E210882) Motherboard
No power at all no lights or anything. replaced the power fuse which was blown still no power rca hd56w66 also replced dp410&dp411 diodes and the fl100 fuse
The whole dawn power supply board is shorted and dead.U have the equipments,a good trouble shooting and electronic skills,trouble shoot all those transformers out put,check all the primary and secondary out put of those coils of those power transformers?Some of those power tranformers are dead needed replacement.Or try website like Tvrepairworld.com to buy a whole refurbish power supply board for the replacement
Nov 07, 2010 | RCA HD56W66 56" HDTV
My Braun electric shaver model 7680 has stopped functioning probably due to a dead battery ( I had it for years). A service center is asking in excess of 60 dollars to fix it. Battery and mother board...
If the shaver is completely dead and the charging lights no longer illuminate when plugged in, the circuit board will need changed. If they still illuminate when plugged in, you can just change the batteries.
You will find the batteries and also the circuit board with batteries at shaveroutlet.com. You can order which you require. See links below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-circuit-board-with-batteries-select-models-p-772.html
There is a tip on the battery page for easier installation
shaveroutlet.com has an instructional video that shows you how to disassemble the shaver at the link below. It's the 4th video down
http://shaveroutlet.com/video_tutorials
Oct 14, 2010 | Braun Syncro 7680 Electric Shaver
I have a Samsung hcm4215w you can hear samsung turn on chime but no picture.Please any advice would be appreciated.
Ur video backlight board is dead,not get power to the board to get picture,must replaced the backlight video board.
Another prob.u could have.
U have tv show sound,but no picture?
Ur inverter board it dead.
Oct 24, 2009 | Samsung HCM4215W 42" Rear Projection...
E210882 is the number on the motherboard on my Emachine computer. i'm trying to disable the onboard video card with a jumpper setting so it will reconize a older but working pci 3dfx monster 3d card I put...
You can disable the onboard by visiting your bios.
On boot it will tell you to press del f8 f2 etc to enter the setup from there you can navigate around to disable the onboard and choose the lane your older pci card is in.
Oct 11, 2009 | Dell (E210882) Motherboard
Battery dead after being replaced less than 4 days ago
Run the stereo system through the fuse panel. It will disconnect the power when the key is off.
Aug 12, 2009 | Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35...
Presario SR1103WM video dead
okay, if you go into bios, try to find where the video source is from or disable it from advanced to components to onboard, select disable
Jan 06, 2009 | HP Compaq Presario SR1720NX (EL435AA) PC...
Emachin
Sometimes this problem happens when your CMOS battery already dead. Replace the CMOS battery and run F4 to setup the date and time. Save it and you back to business.
Mar 27, 2008 | Dell (E210882) Motherboard
Dell (E210882) Motherboard Logo
705 people viewed this question
Alun Cox
