Question about Baby Gear
One of the pins came out that holds the legs in place how do i fix it
  • 340 Answers
Products America services most crib hardware. If you could call us when you are with the crib, we will try to help you. Our contact numbers are 800-772-1041 or 800-205-9642. We are open M-F 8-6 CST.
Posted on Oct 06, 2009
THE LEG AND COTTER PIN CAME APART FROM THE CENTER SPROCKET
From Paul182 himself: I FIXED THIS MYSELF. i HAD TO HOT GLUE THE PINS INTO THE TUBES, AND UNSCREW THE BOTTOM PLATE, THEN TURN THE TUBES 90 DEGREES PUSH DOWN INTO THE SLOT AND ROTATE BACK 90 DEGREES. NOT EASY BUT IT WORKS. THEN SCREW THE PLATE BACK ON.
Apr 14, 2014 | Cosco Juvenile Cosco Funsport Playard
Table broken leg
You need some kind of screws/bolts to hold the broken pieces in place before you can apply glue. At the end of your video, you showed the bottom view of the legs. If you can drill some holes at good positions, you should be able to put bolt and nut to hold the legs in place. Then, you can use super glue to keep the surfaces smooth.
Apr 11, 2014 | Furniture
Can leg warmers be used as arm warmers too?
Yes. It is not what they are meant for and it will look a bit odd, but you definitely can do it if you like it.
If it helps, you can also make little holes for your thombs so that it will look a bit more like an arm warmer.
Dec 26, 2013 | Clothing Accessories
How can I stop my plastic table from blowing away in the wind?
I used stakes and wire to hold my table in place. You getsome garden wire and wrap it around the legs and use pliers to fasten them bytwisting. The you do the same to the metal stakes or camping pins, ensure thatyou drive the stakes or pins firmly into the ground.
May 29, 2012 | Garden
Machine viabrates badly whether empty or loaded. Machine has been checked for balance.
Did you pull the packing strap from the rear legs it is sometimes a yellow pin. lean unit forward look at rear of machine pin holds the legs up for shipping pull that out.set machine down lean unit forward to balance rear legs should be good to go...If I helped you Please vote need more help just ask Good luck...
Feb 03, 2011 | Maytag PAV2300 Top Load Washer
How to i fold it into the space saver option
Make sure the incline is at its lowest point 1. Hold the treadmill with your hands on each side of the frame at back of treadmill To decrease the possibility of injury, bend your legs and keep your back straight. As you raise the treadmill, make sure to lift with your legs rather than your back. Raise the treadmill about halfway to the vertical position. 2. Move your right hand to hold the treadmill firmly in the upright position. Using your left hand, pull the latch knob to the left and hold it. Raise the treadmill until the latch pin is aligned with the hole in the catch. Insert the latch pin into the catch. Make sure that the latch pin is fully inserted into the catch.
May 31, 2010 | Proform Pro Series 1500 Treadmill
Need to install water pump in a 87 lowe pontoon with 30 hp evin rude motor
The water pump is in the leg, you must disconnect the gear linkage and undo the bolts that hold the bottom of the leg in place( pointing up above water intake). Dont forget the one near the propeller. Wiggle the leg and slide downwards. place the leg on the bench , the drive shaft protrudes from the center of the water pump housing. Undo the bolts holding the housing on, and slide it off. Be sure to install the new impeller with the rotors folded in the correct direction to avoid pinching. when re installing the leg be sure to align the water cooling pipes correctly. It is always a good idea to refer to a workshop manual when attempting any maintenance upon machinery.
Cheers, Timo.
Apr 28, 2010 | Boating
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
Need directions on how to fold legs
Hi, I can fix this.
First, on the bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place.....
To unfold, simply press on the holding latches, and pull up.
Good Luck.
Gordon & Shirley
Nov 17, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
