Electrolux Centralux Vacuum
Problem for Electrolux Centralux Vacuum
No suction
By debbrummund on Oct 04, 2009
no suction
Best Solution
posted on Oct 04, 2009
Very Helpful)
Chemist1961
Rank: Guru  Electrolux Vacuums  Expert
Rating: 93%, 131 votes
If this is an Electrolux, start by testing the suction at the inlet nearest the vac or at the 30 degree elbow on the left. If you have suction there but not elsewhere, and can hear the vac running when the hose is plugged in you have blockage in your main line between the vac and the rest of the house.
You should first test the hose, then the inlets one by one. Drop a quarter into the handle of the hose and shake it through to the far end. If it comes out your hose is clear. Next mark a tissue with a number and **** it into the hose at each inlet, checking the bucket to see if teh tissue has claered the lines. If none of the tissue make it to the bucket, , get a shop vac, open the inlet nearest the vac and **** the obstruction backwards out the inlet. As blockage clears you will hear thinks moving in the pipe. Post back with results
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Electrolux Centralux Vacuum
Questions and Unsolved Problems for Electrolux Centralux Vacuum
Do you recommend Electrolux Centralux Vacuum?
Answer
Answer
I just bought a Z1750 twin tech vacuum. I am wondering if I can buy a power brush attachment for... (More)
Answer
Hi I need help with a problem I am having with my Frigidaire Gallery Stainless Steel Dishwasher... (More)
Answer
I want to remove the hose from the handle of the vacuum? I already removed the plastic clip. I... (More)
Answer
How can I clean the filter in the canister of my condolux system? Is it removable?
Answer
The 'self clean filter' icon flashes. Really annoying, what am I doing wrong? It is a electrolux... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Electrolux Centralux Vacuum:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
