Doesnt drain the water out after rinse
Everything works with the washing machine except that it doesnt drain the water out. what could the problem be?
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Blockage @ filter or pump.
Posted on Oct 04, 2009
Maytag clothes washer Model LAT6910AAW. leaks at the last cycle when the rinse water is drained. it may be the drain pump, except it doesn't leak when the wash water is drained (2nd cycle)
If your machine has a tray that you put softener in, softener is the last thing added at rinse time. If it is plugged or has a leaking supply hose, this would cause water paddles and appear to be related to the drain cycle.
Feb 17, 2017 | Maytag Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Rinse cycle doesnt work
Because the water from the wash is still inside it and has not drained. So you need a new drain pump!
Jan 19, 2014 | Speed Queen AWN432 Washer
When the tub fills the water for the wash..as the wash starts filling it doesnt stay in the tube and just flows out from the pipe..what is the problem or reason for it..what should I do for...
chek the outlet of the drain pipe somethings must be stuck in the pipe which is holding the soleniod 2 close,or there is a prob with the outlet drain pump wireing or rod
Dec 04, 2013 | Washing Machines
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Rinse and drain
Just had this problem and fixed it by installing a new timer. Be sure to remember the order the wires were attached on the old timer.
Dec 16, 2007 | Maytag MAV7600 Top Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Machine stopped taking conditioner
Also, if the solution that you have above doesnt work, some model washers use a computer board to control the flow of water through the dispensers.  Not usually likely that they go bad, but they do.  If cleaning it like the first solution doesnt work, it may be a bad board, bad water control valve (the one that controls dispenser water), or bad timer.  Hope your first solution works for sure, usually does.
Oct 10, 2007 | Washing Machines
Washing Machines Logo
164 people viewed this question
Top Washing Machines Experts
