Question about Whirlpool LER4634J Electric Dryer
Whirlpool ler4634pq1 dryer not heating. coils look ok, just a little black. air comes out the vent good. but cold.
    Genius:
  • Whirlpool Master
  • 1,474 Answers
Element or cut out thermostat at fault , see if has reset on back 1st
Posted on Oct 04, 2009
Went to pick up a dryer sum1 was throwing out took it home plug it up 1st was blowing cold air unpluged it then pluged it again to make sure it was tumbling and it was then noticed the dryer was blowing hot air hmmmmm
Posted on Mar 15, 2011
Dryer wont heat for more than 10 minutes when cold
did you clean the vent line?THAT COULD MAKE IT RUN HOT THE AIR CAN'T BLOW OUTSIDE,BUT WITH THE DRYER HAVING HEAT WHEN IT STARTS AND THEN AFTER LIKE 10 MINUTES NO HEAT IT SOUNDS LIKE YOU HAVE BAD GAS COILS,WHEN THE COILS ARE STARTING TO FAIL THEY WILL WORK FOR LIKE THE FIRST 10 TO 20 MINUTES AND WHEN THEY HEAT UP NO GAS,WHEN THE COOL THEY WILL WORK AGAIN,I WOULD CHANGE THE COILS AND CLEAN OUT THE DRYER AND VENT LINE,THIS SHOULD BE DONE ONCE A YEAR SO YOU DON'T HAVE A FIRE AND YOUR CLOTHES WILL DRY ON TIME,EVERYONE THINKS SOMETHING IS WRONG WITH THE DRYER AND ALL THAT HAPPENS IS THE VENT LINE AND THE DUCT WHERE THE LINT FILTER SLIDES INTO FILLS WITH LINT AND THE AIR CAN'T BLOW AROUND GOOD ANYMORE,ALSO WITH A SHOP VAC VAC UP THE LINT WHERE THE BURNER AND MOTOR IS AND THEN SET THE VAC UP TO BLOW AND BLOW THE MOTOR AND GAS BURNER OUT,DO THIS AND YOU'LL HARDLY HAVE ANY PROBLEMS WITH THE DRYER
Sep 30, 2017 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Whirlpool dryer won't dry clotes Model# LER4634PQ1
Dear Sir:
Please see this possibles causes:
Power from the house
test for blown fuse or c. breaker tripped, change or reset.
Heating element
test for burn or open heating element see the video
Thermal fuse
test for open fuse, see the video
Wiring
test for burn or break wires. test for continuity.
God bless you
May 23, 2012 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool dryer model LER4634JQ0. It now takes many cycles to dry the clothers. I checked the vent coming out, it is not clogged. I can reach in and feel a little fan motor, which I assume...
your vent line from the wall to the outside of the house can be clogged
or your you high heat coil is burned out and just the low heat coil is working, when you switch to high, both coils work. or you have a one coil system and the heat selector maybe defective
Please rate/vote the response Thanks
Dec 20, 2010 | Whirlpool Dryers
HOW CAN A DRYER IGNITE A FLAME AT FIRST FOR TEN MINS THEN WHEN THE DRYER WANTS TO HEAT UP AGAIN I SEE A GLOW BUT NO FLAME COMES THE SECOND TIME SHOULD I REPLACE THE THERMAL FUSE
No you should replace the coils. 3a3915a.jpgWhy? You know you are getting power to the gas assembly so that means the fuse and control are functioning. The igniter glows so that is good. The Flame detect is fine because it shuts down the glowbar when it heats up. So those pesky coils get hot and quit. They eventually cool back down and work a little more, very aggervating to diagnose but easy to fix.2b3709e.jpgNote you do not have to remove the gas assembly to replace these coils.
Apr 23, 2010 | Whirlpool Dryers
Coils in the back of my whirlp dryer get ht then instantly go out
If the coils get hot then cold it is most likely the problem of the venting. If the heated moist air cannot leave the dryer then the heat will not come back on. You can try removing and cleaning the vent with a vacuum or even a leaf blower ( from the inside of the home to outside )
Apr 17, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer LGR6636PWO heats for appro. 5 minutes & quits heating but still runs.
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
Oct 04, 2009 | Whirlpool LGR6636 Gas Dryer
Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool LGN2000LWH Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
1,011 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
