Question about Canon PowerShot A470 Digital Camera
The lcd screen will not come on. Batteries are fine. Just stopped working.
Fuji HS20EXR wont turn on after turning off
A defective rechargeable battery caused this on my camera, not sure about the blue haze though. Make sure battery is good or use fresh alkalines.
Mar 24, 2014 | FUJIFILM HS20 EXR Digital Camera
LCD screen Black - manual Zoom not working
Hey,
It sounds like you're having the same problem,
Here is a link
http://www.e18error.com/repair.html
It may be usefull,
good luck mate!
Jul 26, 2010 | Canon PowerShot A630 Digital Camera
I switch the canon Ixus 60 on in camera mode and the LCD screen is blank. THe LCD screen works fine in video and review mode.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Jan 17, 2010 | Canon Cameras
Kodak z760 lcd screen will not work in the auto
It could have something to do with the batteries/ battery compartment: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 14, 2010 | Kodak EasyShare Z760 Digital Camera
My dynex remote control for 32 inch flat screen stopped working, tried new batteries-no fix, any help? Can I use another or do I have to contact the company for a new remote?
I just called Dynex because I had the same problem. Remove the batteries and press the power button and hold it down for 15-20 seconds, put the batteries back in and try to power on and power off, change channels, etc... if so the remote is fine. The guy told me that sometimes when you need to replace the batteries you also have to re-set the remote control.
Jan 09, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Television displays in blue , only checked all
For your remote problem, mine has stopped working a couple of times and here is what Sharp had me do: Take the batteries out of the compartment. Next press and hold down the power button on the remote for a count of 30 seconds. Return batteries and the RC should be reset. As for the other problem, I had a similar thing happen tonight, hence I am on this site looking for help. My remote quite working, so I did the above, to no avail. I noticed the channel number box was frozen on the screen. I could not turn the TV off manually and had to unplug from AC. I plugged it back in and got sound but no picture, just that bluish dark screen. TV would not turn off. Then I got nothing, no sound, no pic. I left the TV unplugged for several minutes, 5 or so, plugged it in and it did work and is working now, RC too. You might try unplugging it for an extended time.
Jun 11, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No picture on lcd screen only when taking pictures
Did you accidentally press the DISP or DISPLAY button on back (it turns the screen off to save batteries). If so, press this button again to turn your LCD screen back on.
Oct 07, 2008 | Canon Cameras
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
Axion handheld tv. No picture at all.
I have on and if the batteries start getting weak the screen display brightness is the first to stop working. Double check that, if you are on AC power try sliding the brightness control from dim to bright a few times and see if the rheostat has corroded. Those are a few of the quick checks you can try, let me know. Jay
Jan 21, 2008 | HandHeld Entertainment Axion 2.5'' TFT LCD...
Canon PowerShot A470 Digital Camera Logo
19 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
