Question about Crane Plumbing Home
1952 Crane bathtub/shower drain assembly diagram
I have a circa 1952 Crane bathtub supply and drain that has a two handle supply and a lever in the center of the air vent to open and close the drain. There is no drain cover in the drain hole.
Recently the tub has been leaking to the lower level. I noticed if I cover the air vent assembly and pour water over the general area there is no leak.
I am assuming that something has gone wrong with the assembly. I am looking for a parts diagram and repair instructions if available.
Washer_tech
  • 164 Answers
SOURCE: leaking water from underneath.
sounds like several problems. sounds like your boot stem/ seal is leaking and possibly the tub bearing is rusted. I generally replace both at the same time as long as the machine is apart anyway. As for the squealing and tub slamming to a stop, that is your brake package and bearing have dried and/or rusted and need to be replaced
Posted on Dec 26, 2007
blueextc3221
  • 15935 Answers
SOURCE: my price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Posted on Dec 26, 2008
  • 14 Answers
SOURCE: Leaking tub spout single handle volumne/thermostat
See if you can give me a head on picture.
From the top it looks like it could be a Kohler or Grohe.
Thanks,
sanray
Posted on Dec 28, 2008
  • 63 Answers
SOURCE: bathtub whirlpool leaks. problem is that the tub
Stop leak in a bottle absolutely does not work, look closely there should be some sort of access panel (maybe well hidden) to get under there.
Posted on Mar 24, 2009
co7196
  • 3433 Answers
SOURCE: water is leaking from my downstairs air conditioning vent
I seriously doubt it's the AC. It may be the draing in the upstairs shower, If it's a water line it is a very small leak and is probably puddling in you ceiling. if not nbeing absorbed. Best thing is contact your homeowners insurance because you are going to not only have a plumber to deal with , but a mols issue as well. Sorry, good luck.
Posted on May 31, 2009
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
Hi,I have a Bathtub Shower Valve that is not working
SHUT OFF THE WATER SUPPLY VALVE BEHIND THE SHOWER.THOSE HANDLES ARE DIFFICULT TO REMOVE,SQUIRT WD-40,LET IT SOAK IN,THEN GIVE IT A LITTLE TAP ON THE HANDLE ,BE CAREFUL NOT TO DAMAGE IT.IF YOU CAN NOT STILL REMOVE THE HANDLE,THEY SELL A HANDLE PULLER,
Apr 20, 2010 | American Standard Home
The lever that pulls up and down on the spout doesnt work well .
You can adjust the length of the connection piece which opens/closes the plunger to close the drain. Remove the handle assembly from the tub and lengthen/shorten the assembly as needed to be able to seal the drain.
Apr 10, 2010 | Home
Slow drip from Delta single lever shower faucet
remove handle with allen wrench then unscrew sliver ring that covers ball with stem sticking out you might need a strap wrench if the threads are corroded
Mar 07, 2010 | Home
I have a Home circa 1960s and I believe the faucets in the Bathtub are just as old. They do not have a name on them so I can find out who might have parts. Any idea where a manufacturer might hide their...
Usually the name is marked on the escutions rings. Bring the handle and stem if you can remove to a hardware store and they might be able to identify the faucet by looking at the handle.
Jan 17, 2010 | Moen & One Handle Tub & Shower Faucet
I have a positemp one lever bathtub handle. we
Because the tile was added after the valve was set to correct depth, you will have to get a extention kit. They are only available at a supply house. This will extend handle further away so the handle wont scratch any more.
Sep 26, 2009 | Moen & One Handle Tub & Shower Faucet
I get a leak only when the shower bathtub faucet is turned on, its not the drain nor the shower head, please help....
check the bath faucet handle and the protective cover just beneath. if the water comes from here then remove handle and lower cover & tighten the nut on the insert and test without the cover
Aug 19, 2009 | Home
Bath tub drain
You need to replace the overflow cover with the lever on it.You can replace the entire piece or just the faceplate.There is a spring on most of these that holds the lever in place when thrown and that is the piece that is broken causing your issue. Thanks for using Fix Ya.
Mar 02, 2009 | Delta T13420 Chrome Classic Single Handle...
Home Logo
1,041 people viewed this question
Top Crane Plumbing Home Experts
Donni Steen
john h
Tom Chichester
Are you a Crane Plumbing Home Expert? Answer questions, earn points and help others
