Question about Dacor CM24P
Dacor CM24P Coffee system Error message
Error message"Too much coffee". We have removed all the beans and reloaded but the message will not clear.
  • beckerj Oct 04, 2009
    took your advice but suspected this was not the problem as coffee bean hopper was never "overloaded" in the first place. Error message re-appeared. Grind time has never been changed from factor default setting. Any further advice?
  • beckerj Oct 05, 2009
    what is the default setting? I have read the instructions but it does not state what the grind time should be. Is there a way to reset all settings?
    We have never used the ground coffee option.
  • 8,197 Answers
There is too much coffee put in the ground coffee chute. Reduce the amount (there should be only 1 to 1 1/4 scoops in the chute). If the ground coffee chute is not being used, the grind time may be programmed incorrectly. Shorten the grind time to the default setting following the instructions in the Use and Care Manual.
Good luck
Posted on Oct 04, 2009
  • Jyackle5
    Jyackle5 Oct 05, 2009
    Sorry there is no way to reset all settings.
Continuous steam coming out of my cappuccino machine
I have a Dacor Coffee System/ Built in...when i turn on the CN12- check steam temp. and steam comes out. how do i fix this?
Rick
Aug 18, 2013 | Dacor CM24P-1 Coffee Maker
When system is turned on Steam immediately begins to come out and error code CN12 appears
Hello, i have the same problem...did you get the answer on how to fix this CN12 error/ steam coming out on your Dacor Coffee system? RickPulsinelli@gmail.com
Feb 15, 2011 | Dacor CM24P-1 Coffee Maker
Brewing system plastic part broken
if you really like the unit i will sell you mine and you will have a complete inventory of parts
Apr 25, 2009 | Dacor CM24P-1 Coffee Maker
WE NEED A PLUNGER O RING FOR THE DACOR CM24P
I picked one at my local hardware store. We have a VERY good store and that has basically everything. Take the part with you to a similar store or a bearing seal place.
Jan 19, 2009 | Dacor CM24P-1 Coffee Maker
I just bought the coffee maker and it says the drawer is open
I have a CM24P that had the power supply short out and I have decided not to repair due to the high cost of replacement parts. I have decided to part my unit out. Send part requests to Rick at pittsburgh.stillers@gmail.com.
This unit was in service for about 6 months.
Nov 26, 2008 | Dacor CM24P-1 Coffee Maker
Dacor CM24P will not dump coffee?
I have the same problem and a technician came in to look at it today. I need a press assembly unit (I think it runs about $600). He said it could simply be caused by using "sticky" coffee beans. He ran the machine, holding the door closed button with his hand so we could see the machine run it got stuck every time like it was moving through tar- even after cleaning. I'm looking at about $300 of labor and a $600 part. We ought to file class action suit against Dacor. My machine has never worked properly.
Oct 08, 2008 | Dacor CM24P-1 Coffee Maker
Dacor CM24p
Dacor has a set up on their web site (see link below) that lets you enter your information (eg. postal code) and then looks up the closest repair/ parts places. Note if you want parts check the box that says you're looking for parts.
http://www.dacor.com/Customer-Care/Locate-A-Servicer.aspx
Jul 17, 2008 | Dacor CM24P-1 Coffee Maker
Repeat error message
I've been through this with my Dacor coffee machine. I believe there is NO fix! Dacor replaced my entire plunger assembly and now it keeps sticking. The too much coffee error has gone but now I'm getting a persistent group error because of it getting stuck. I agree with "lilyfish" I wouldn't have purchased it either and to boot they have stopped making coffee machines!!! I'm looking at a Miele now.
Mar 21, 2008 | Dacor CM24P-1 Coffee Maker
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Dacor Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Michael Vincent Cruz
Tom Chichester
Are you a Dacor Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
